Defining Commodity Codes
This portal is used to view and maintain commodity codes.
You can access the portal from Admin, select C, then select Commodity Code.
The Commodity Code Hierarchy zone on the portal's Main tab page displays a hierarchical view of all commodity codes.
Parent topic
