Defining Compatible Unit Sets
The Compatible Unit Set portal is used to display and maintain compatible unit sets.
You can access the portal from Admin, select C, then select Compatible Unit Set. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
• Compatible Unit Set: This zone provides information about the compatible unit set.
• Compatible Units: This zone displays a table of the compatible units in the set.
• Compatible Units Hierarchy: This zone displays a tree view of the compatible units in the set.
• Attachments: This zone enables users to manage all types of attachments for the compatible unit set record.
• Notes: This zone displays notes about the compatible unit set.
Parent topic
