Defining Compatible Units
The Compatible Unit portal is used to display and maintain compatible units.
You can access the portal from Admin, select C, then select Compatible Unit. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
• Compatible Unit: This zone provides information about the compatible unit.
• Compatible Unit Hierarchy: This zone displays a hierarchy tree view of the compatible unit.
• Contractor Bids: This zone displays contractor bid details associated with the compatible unit.
• Referencing Compatible Units: This zone displays a table view of compatible units that reference the current compatible unit.
• CUs for the Same CU Set: This zone displays a table view of compatible units that are in the same compatible unit set.
• Attachments: This zone enables users to manage all types of attachments for the compatible unit record.
• Notes: This zone displays note information about the compatible unit.
The following zones may appear as part of the portal's Resources tab page:
• CU Materials: This zone displays material cost details, such as Stock Item, Unit of Issue, Quantity, Unit Price, and any derived costs.
• CU Labor and Equipment: This zone displays labor and equipment cost details, such as Craft, Number of People, Hours Per Person, Craft Rate, Total Hours, and any derived cost associated with labor and then Equipment, Unit of Measure, Quantity, Duration, Equipment Rate, Total Duration, and any derived costs associated with equipment.
Parent topic
