Defining Configuration Reports
The Configuration Report portal is used to display and maintain configuration reports.
You can access the portal from Admin, select C, then select Configuration Report. You are brought to a query portal with options for searching for a specific configuration report. Once the configuration report has been selected, you are brought to the maintenance portal to view and maintain the selected record.
• Configuration Report: This zone provides report criteria about the selected configuration report.
Parent topic
