Defining Crews
The Crew portal is used to display and maintain crews.
You can access the portal from Admin, select C, then select Crew. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
• Crew: This zone provides information about the crew, such as primary and secondary crew members, default crew service classes and crew service areas.
• Shift Plan Template: This zone provides details about the shift plan template.
• Crew Calendar: This zone displays a calendar view of the crew’s shifts.
Parent topic
