Defining Failure Causes
The Failure Cause portal is used to display and maintain failure causes.
You can access the portal from Admin, select F, then select Failure Cause.
• Failure Cause List: This zone lists all failure cause records. Broadcast a record to display the details of the selected record.
• Failure Cause: This zone provides information about the cause of the failure, such as bent, collapsed, twisted, and so on.
• Included on Failure Profile: This zone lists the failure profiles associated with a particular failure.
Parent topic
