Defining Failure Components
The Failure Components portal is used to display and maintain failure components.
You can access the portal from Admin, select F, then select Failure Component.
• Failure Component List: This zone lists all failure component records. Broadcast a record to display the details of the selected record.
• Failure Component: This zone identifies the part of the asset which has failed, such as instrument, electrical, mechanical drive, and so on.
• Included on Failure Profile: This zone lists the failure profiles associated with a particular failure component.
Parent topic
