Defining Overheads
The Overhead portal is used to display and maintain overhead details.
You can access the portal from Admin, select O, then select Overhead.
• Overhead List: This zone lists all overhead records. Broadcast a record to display the details of the selected record.
• Overhead: This zone provides percentage details for Additional Overhead not specific to any Resource Type as well as Work Designs and Construction Work Orders associated with a selected overhead, including material overhead, labor overhead, equipment overhead, and other overhead.
Parent topic
