Defining Planners
The Planner portal is used to display and maintain planner records.
You can access the portal from Admin, select P, then select Planner.
• Planner List: This zone lists all planner records. Broadcast a record to display the details of the selected record.
• Planner: This zone provides information about the selected planner.
Parent topic
