Defining Shift Templates
The Shift Template portal is used to view and maintain a shift template as part of setting up a shift plan template.
You can access the portal from the shift templates zone on the shift plan template.
• Crew Shift Template: This zone provides information about the shift, including the various maintenance actions applicable to its current state.
• Overridden Shifts: This zone shows shifts that were generated by this template but their setup has since been manually changed from the setup defined by the template.
Parent topic
