Asset Removal
When a previously synchronized GIS feature is deleted in the GIS system, the next synchronization process detects this change as a Removal operation that results in the following changes:
• The corresponding asset location is marked inactive.
• The GIS global identifier reference on the asset location is removed since a feature with that identifier no longer exists in the GIS system.
• The corresponding asset is retired and moved to the default out of service location defined on the Esri WAM Integration master configuration record.
Parent topic
