Maintaining Inbound Communications
This portal is used to view and maintain inbound communications.
You can access the portal from Admin, select I, and then select Inbound Communication. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
• Inbound Communication: This zone displays information, such as activity, asset, location, and event information, about the inbound communication.
• Communication Tree: This zone displays a tree view of communications and events for the selected inbound communication.
Parent topic
