Level | Entity | Comment |
1 | Your organization’s country. | |
1 | Your organization’s currency. The overall system uses the base currency defined in Installation Options, and all financial transactions use the base currency. However, the purchasing system supports other currencies which can be defined in the Currency portal. | |
1 | Controls how dates, times, and numbers are displayed. | |
1 | The language to use for this implementation. | |
1 | Your organization’s base time zone. | |
1 | Used to associate users with To Do entries. | |
1 | The work calendar for your organization which identifies your public holidays. | |
1 | If your company uses geographic coordinates for dispatching or geographic information system integration, you need to setup a geographic (coordinate) type for each type of geographic coordinate you capture for assets. | |
1 | The "lookup" table is a single table that holds valid values for many columns on many tables. Extendable lookups are custom fields where valid values are limited to a predefined list. | |
1 | The "lookup" table is a single table that holds valid values for many columns on many tables. Lookups are custom fields where values can be added. Only lookups where the “Custom” flag is checked can be modified. | |
1 | Prerequisites: Business Object and Schema | |
1 | You will need to set up an algorithm that populates global context values. The global context is used by various zones in the system to display relevant data. This algorithm is plugged-in on the installation record. | |
2 | Controls various aspects of the system. You must set up ‘Address Information’ and ‘Global Context’ algorithms. | |
2 | Used to define types of To Do Entries. | |
2 | Prerequisites: The Checkbox Feature Configuration needs the custom UI Maps. Add a feature configuration of feature type ‘Schema Constants’ and set the value for ‘Default Country’. | |
2 | If you need to introduce additional fields to objects that were delivered with minimal fields, you can add a characteristic type for each field you want to capture. | |
2 | If you are using an integration you must configure the external system in this portal. |
