Understanding Home Page Configuration
Please refer to
About Home Page in the
Business User Guide for a conceptual overview of home page functionality.
Beyond entering Master Configuration settings for the home page, you might also consider the following:
Configure User Settings for the Home Page
Users can add or remove zones on the
Home Page by navigating to
Preferences and selecting the
Portal Preferences tab. Here, under the various Home Page sections, you can select which default zones display, whether or not they are initially collapsed or expanded, and the order in which they appear. Depending on your business practices, you can choose to disable this ability for users by modifying their access to these settings by assigning a
Template User for
Portal Preferences to each
User record. Refer to
Understanding Portals and Zones, or the
User - Portal Preferences section under
User Preferences in the
Oracle Utilities Application Framework documentation for more information on using portal preferences.
Add Zones to the Home Page
You may find that it is beneficial to include additional zones on the
Main tab of the
Home Page, such as a zone to show
Saved Searches,
Bookmarks, or
Favorites. You may also want to add organizational information such as a company news zone or additional custom zones. You can configure the Home Page, or any portal, to display the zones that you choose by configuring zone settings as described under
Understanding Portals and Zones in the
Oracle Utilities Application Framework documentation.
Parent topic
