About 360 Degree Search
The 360 Degree Search portal is used to search for assets, components, specifications, locations and contacts. Users can also search on other identifiers or characteristics as defined by your organization.
You can access the portal from Menu, then select 360 Degree Search. You are brought to the 360 Degree Search portal with options for searching.
Selecting different Search By criteria from the portal’s Main tab page will change the search fields to present different options. From the search results list, you can navigate to the selected portal to view data for the object.
This feature is only used in Oracle Utilities Operational Device Management.
Parent topic
