About 360 Degree View
The 360 Degree View feature allows users to view data for assets, components, contacts and locations from a single set of portals.
The 360 Degree View has a separate portal for each type of object:
• Asset Information
• Asset ID
• Asset Specification
• Asset Location Information
• Storeroom Information
• Location ID
• Contact Name
Once you select one object, the 360 Degree View provides related information so that you have full visibility into all information about that object. For example, if you select Asset Information and search on an asset type, the resulting view portal shows the components, service history, activity history, and location information for assets of that asset type.
This feature is only used in Oracle Utilities Operational Device Management.
Parent topic
