Maintaining Approval Requests
This portal is used to view and maintain approval requests.
You can access the portal from Menu, select Home Page, then select the Approvals tab. Broadcast the Document Type and then select the Approval Request ID hyperlink from within the Approval Detail List zone.
The Approval Request zone on the portal's Main tab page provides information about the approval request, including approvers, approval amounts, approval profile, etc.
Parent topic
