Maintaining Bill of Materials
The Bill of Materials portal is used to display and maintain a bill of material record.
You can access the portal from Menu, select Asset Management, then select Bill of Materials. You are brought to a query portal with options for searching for a specific bill of material. Once a bill of material has been selected, you are brought to the maintenance portal to view and maintain the selected record.
• BOM Tree: This zone displays a hierarchy view of the selected BOM and BOM parts.
• Bill of Materials: This zone displays information about the bill of material record.
• Referencing BOM’s: This zone lists the BOMs that reference this particular BOM record.
• Attachments: This zone enables users to manage all types of attachments for the BOM record.
• Notes: This zone displays any notes associated with the bill of material record.
Parent topic
