Maintaining Field Activities
The Field Activity portal is used to view and maintain field activities.
You can access this portal from Menu, select Work Management, then select Field Activity. You are brought to a query portal with options for searching for specific record. Once the field activity has been selected, you are brought to the maintenance portal where you can view and maintain the selected record.
The following zones may appear as part of the portal’s Main tab page:
• Field Activity: This zone displays general information, such as location, asset, service class, and so on about the selected field activity record.
• Completion Information Entry: This zone displays a list of completion events for the field activity.
• Attachments: This zone enables users to manage all types of attachments for the field activity record.
The following zones may appear as part of the portal’s Cost tab page:
• Activity Cost Summary: This zone displays a summary of costs associated with the field activity record.
Parent topic
