Maintaining Maintenance Plan Triggers
The Maintenance Plan Trigger portal is used to display and maintain a maintenance plan trigger record.
You can access the portal from Menu, select Preventive Maintenance, then select Plan Trigger. You are brought to a query portal with options for searching for a specific record. Once a plan trigger has been selected, you are brought to the maintenance portal to view and maintain the selected record.
• Plan Trigger: This zone displays information about the plan trigger record, such as processing information and work order defaults.
• Activity: This zone lists the work activities associated with the plan trigger record.
Parent topic
