Maintaining Maintenance Plans
The Maintenance Plan portal is used to display and maintain a maintenance plan record.
You can access the portal from Menu, select Preventive Maintenance, then select Maintenance Plan. You are brought to a query portal with options for searching for a specific record. Once a maintenance plan has been selected, you are brought to the maintenance portal to view and maintain the selected record.
• Maintenance Plan: This zone displays information about the maintenance plan.
• Plan Trigger: This zone lists all the triggers associated with the maintenance plan.
• Maintenance Event: This zone lists the maintenance events associated with the maintenance plan.
Parent topic
