usage | com.oracle.ouaf.oem.conversion.ConversionSetup |
-a, --apply | Apply Conversion setup on Staging Schema. '-s' is mandatory if '-a' is passed |
-d,--dbConnString <arg> | DB connection string: Any "jdbc:oracle:thin"supported format [example: HOST:PORT/SID | HOST:PORT:SERVICE | <TNSSTRING>] |
-o,--output <arg> | Output Directory for the generated files. Directory will be created if it doesn't already exist. |
-p,--prodSchema <arg> | Primary/Production Schema and credentials to connect: CIS_ADMIN,CIS_PSWD. [example: CISADM,CISADM] |
-r,--rollback | Revert Conversion setup on Staging Schema. '-s' is mandatory if '-r' is passed |
-s,--stgSchema <arg> | Staging Schema and Staging users:STG_ADMIN,STG_PSWD,STG_RW_USER [example: STGADM,STGADM,STGUSER] |
