Table Name | Upgrade Action | Description |
CI_ALG | MG | Algorithm |
CI_ALG_L | MG | Algorithm Language |
CI_ALG_PARM | MG | Algorithm Parameters |
CI_ALG_TYPE | MG | Algorithm Type |
CI_ALG_TYPE_L | MG | Algorithm Type Language |
CI_ALG_TYPE_PRM | MG | Algorithm Type Parameter |
CI_ALG_TYPE_PRM_L | MG | Algorithm Type Parameter Language |
CI_ALG_VER | MG | Algorithm Version |
CI_APP_SVC_ACC | MG | Application Service Access Mode |
CI_BATCH_CTRL | MG | Batch Control |
CI_BATCH_CTRL_ALG | MG | Batch Control Algorithm |
CI_BATCH_CTRL_L | MG | Batch Control Language |
CI_BATCH_CTRL_P | MG | Batch Control Parameters |
CI_BATCH_CTRL_P_L | MG | Batch Control Parameters Language |
CI_CHAR_ENTITY | MG | Characteristic Type Entity |
CI_CHAR_TYPE | MG | Characteristic Type |
CI_CHAR_TYPE_L | MG | Characteristic Type Language |
CI_CHAR_VAL | MG | Characteristic Type Value |
CI_CHAR_VAL_L | MG | Characteristic Type Value Language |
CI_CURRENCY_CD | KP | Currency Code |
CI_CURRENCY_CD_L | KP | Currency Code Language |
CI_DISP_ICON | MG | Display Icon |
CI_DISP_ICON_L | MG | Display Icon Language |
CI_DISP_PROF | KP | Display Profile |
CI_DISP_PROF_L | KP | Display Profile Language |
CI_FK_REF | MG | Foreign Key Reference |
CI_FK_REF_L | MG | Foreign Key Reference Language |
CI_LANGUAGE | MG | Language Code |
CI_LOOKUP_FIELD | MG | Lookup Field |
CI_LOOKUP_VAL | MG | Lookup Field Value |
CI_LOOKUP_VAL_L | MG | Lookup Field Value Language |
CI_MD_AT_DTL | RF | MD Element Attribute Type Detail |
CI_MD_AT_DTL_L | RF | MD Element Attribute Type Detail Language |
CI_MD_ATT_TY | RF | MD Element Attribute Type |
CI_MD_CONST | MG | Constraints |
CI_MD_CONST_FLD | MG | Constraint Fields |
CI_MD_CTL | RF | Generator Control |
CI_MD_CTL_L | RF | Generator Control Language |
CI_MD_CTL_TMPL | RF | Generator Control Template |
CI_MD_ELTY | RF | MD Element Type |
CI_MD_ELTY_AT | RF | Element Type Attributes |
CI_MD_ELTY_L | RF | Element Type Language |
CI_MD_FLD | MG | Field |
CI_MD_FLD_ADDTL | MG | Field Additional Attributes Table |
CI_MD_FLD_L | MG | Field Language |
CI_MD_LOOKUP_F | RF | MD Lookup Field |
CI_MD_MENU | MG | Menu Information |
CI_MD_MENU_IMOD | MG | Menu Item Module Maint |
CI_MD_MENU_ITEM | MG | Menu Item |
CI_MD_MENU_ITEM_L | MG | Menu Item Language |
CI_MD_MENU_L | MG | Menu Language |
CI_MD_MENU_LINE | MG | Menu Line |
CI_MD_MENU_LINE_L | MG | Menu Line Language |
CI_MD_MENU_MOD | MG | Menu Product Components |
CI_MD_MO | MG | Maintenance Object |
CI_MD_MO_ALG | MG | Maintenance Object Algorithm |
CI_MD_MO_L | MG | Maintenance Object Language |
CI_MD_MO_OPT | MG | Maintenance Object Option |
CI_MD_MO_TBL | MG | Maintenance Object Table |
CI_MD_MO_WRK | MG | Maintenance Object Work Tables |
CI_MD_MSG | RF | MD Message |
CI_MD_MSG_L | RF | MD Message Language |
CI_MD_NAV | MG | Navigation Key |
CI_MD_PDF | RF | Predefined Fields |
CI_MD_PDF_VAL | RF | Predefined Values |
CI_MD_PRG_COM | MG | Program Components |
CI_MD_PRG_EL_AT | MG | UI Page Element Attributes |
CI_MD_PRG_ELEM | MG | UI Page Elements |
CI_MD_PRG_LOC | MG | Program Location |
CI_MD_PRG_MOD | MG | Program Module |
CI_MD_PRG_SEC | MG | UI Page Sections |
CI_MD_PRG_SQL | MG | MD SQL Meta Data |
CI_MD_PRG_TAB | MG | UI Tab Meta Data |
CI_MD_PRG_VAR | MG | Program Variable |
CI_MD_SO | MG | Search Object |
CI_MD_SO_L | MG | Search Object Language |
CI_MD_SO_RSFLD | MG | Search Object Result Field |
CI_MD_SO_RSFLDAT | MG | Search Object Result Field Attribute |
CI_MD_SOCG | MG | Search Object Criteria Group |
CI_MD_SOCG_FLD | MG | Search Object Criteria Group Field |
CI_MD_SOCG_FLDAT | MG | Search Criteria Group Field Attribute |
CI_MD_SOCG_L | MG | Search Object Criteria Group Language |
CI_MD_SOCG_SORT | MG | Search Criteria Group Result Sort Order |
CI_MD_SRC_TYPE | RF | Source Type |
CI_MD_SRC_TYPE_L | RF | Source Type Language |
CI_MD_SVC | MG | MD Service |
CI_MD_SVC_L | MG | MD Service Language |
CI_MD_SVC_PRG | MG | MD Service Program |
CI_MD_TAB_MOD | MG | UI Tab Module |
CI_MD_TBL | MG | MD Table |
CI_MD_TBL_FLD | MG | MD Table Field |
CI_MD_TBL_FLD_L | MG | MD Table Field Language |
CI_MD_TBL_L | MG | MD Table Language |
CI_MD_TMPL | RF | Template |
CI_MD_TMPL_ELTY | RF | Template Element Types |
CI_MD_TMPL_L | RF | Template Language |
CI_MD_TMPL_VAR | RF | Template Variable |
CI_MD_TMPL_VAR_L | RF | Template Variable Language |
CI_MD_VAR | RF | Variable |
CI_MD_VAR_DTL | RF | Variable Detail |
CI_MD_VAR_DTL_L | RF | Variable Detail Language |
CI_MD_WRK_TBL | MG | Work Table |
CI_MD_WRK_TBL_L | MG | Work Table Language |
CI_MD_WRK_TBLFLD | MG | Work Table Field |
CI_MSG | MG | Message |
CI_MSG_CATEGORY | MG | Message Category |
CI_MSG_CATEGORY_L | MG | Message Category Language |
CI_MSG_L | MG | Message Language |
CI_NAV_OPT | MG | Navigation Option |
CI_NAV_OPT_CTXT | MG | Navigation Option Context |
CI_NAV_OPT_L | MG | Navigation Option Language |
CI_NAV_OPT_USG | MG | Navigation Option Usage |
CI_PORTAL | MG | Portal |
CI_PORTAL_L | MG | Portal Language |
CI_PORTAL_OPT | MG | Portal Option |
CI_PORTAL_ZONE | MG | Portal Zone |
CI_SCR | MG | Script |
CI_SCR_CRT | MG | Script Criteria |
CI_SCR_CRT_GRP | MG | Script Criteria Group |
CI_SCR_CRT_GRP_L | MG | Script Criteria Group Language |
CI_SCR_DA | MG | Script Data Area |
CI_SCR_FLD_MAP | MG | Script Field Mapping |
CI_SCR_L | MG | Script Language |
CI_SCR_PRMPT | MG | Script Prompt |
CI_SCR_PRMPT_L | MG | Script Prompt Language |
CI_SCR_STEP | MG | Script Step |
CI_SCR_STEP_L | MG | Script Step Language |
CI_SEQ | MG | Sequence |
CI_TD_DRLKEY_TY | MG | To Do Type Drill Key |
CI_TD_SRTKEY_TY | MG | To Do Type Sort Key |
CI_TD_SRTKEY_TY_L | MG | To Do Type Sort Key Language |
CI_TD_TYPE | MG | To Do Type |
CI_TD_TYPE_L | MG | To Do Type Language |
CI_TIME_ZONE | KP | Time Zone |
CI_TIME_ZONE_L | KP | Time Zone Language |
CI_UI_ZONE | MG | Context Sensitive Zone |
CI_USR_NAV_LINK | MG | User Favorite Links |
CI_USR_PORTAL | KP | User Portal |
CI_XAI_ADAPTER | MG | XAI Adapter |
CI_XAI_ADAPTER_L | MG | XAI Adapter Lang |
CI_XAI_CLASS | MG | Message Class |
CI_XAI_CLASS_L | MG | Message Class Language |
CI_XAI_ENV_HNDL | MG | XAI Envelope Handler |
CI_XAI_ENV_HNDL_L | MG | XAI Envelope Handler Language |
CI_XAI_IN_SVC | MG | XAI Inbound Service |
CI_XAI_IN_SVC_L | MG | XAI Inbound Service Language |
CI_XAI_JNDI_SVR | KP | XAI JNDI Server |
CI_XAI_JNDI_SVR_L | KP | XAI JNDI Server Language |
CI_XAI_OPTION | KP | Message Option |
CI_XAI_SENDER | KP | Message Sender |
CI_XAI_SENDER_L | KP | Message Sender Language |
CI_XAI_SNDR_CTX | KP | Message Sender Context |
CI_XAI_SVC_PARM | MG | XAI Inbound Service Parameters |
CI_ZONE | MG | Zone |
CI_ZONE_HDL | MG | Zone Type |
CI_ZONE_HDL_L | MG | Zone Type Language |
CI_ZONE_HDL_PRM | MG | Zone Type Parameters |
CI_ZONE_HDL_PRM_L | MG | Zone Type Parameters Language |
CI_ZONE_L | MG | Zone Language |
CI_ZONE_PRM | MG | Zone Parameters |
F1_BUS_OBJ | MG | Business Object |
F1_BUS_OBJ_ALG | MG | Business Object Algorithm |
F1_BUS_OBJ_L | MG | Business Object Language |
F1_BUS_OBJ_OPT | MG | Business Object Option |
F1_BUS_OBJ_STATUS | MG | Business Object Status |
F1_BUS_OBJ_STATUS_ALG | MG | Business Object Status Algorithm |
F1_BUS_OBJ_STATUS_L | MG | Business Object Status Language |
F1_BUS_OBJ_STATUS_OPT | MG | Business Object Status Option |
F1_BUS_OBJ_STATUS_RSN | MG | Status Reason |
F1_BUS_OBJ_STATUS_RSN_CHAR | KP | Status Reason Characteristic |
F1_BUS_OBJ_STATUS_RSN_L | MG | Status Reason Language |
F1_BUS_OBJ_TR_RULE | MG | Business Object Transition Rule |
F1_BUS_OBJ_TR_RULE_L | MG | Business Object Transition Rule Language |
F1_BUS_SVC | MG | Business Service |
F1_BUS_SVC_L | MG | Business Service Language |
F1_CRYPTO_KEY_RING | KP | Key Ring Table used to store cryptographic keys |
F1_CRYPTO_KEY_RING_L | KP | Key Ring Language Table |
F1_DATA_AREA | MG | Data Area |
F1_DATA_AREA_L | MG | Data Area Language |
F1_DB_OBJECTS_REPO | MG | Database Objects Repository |
F1_EXT_LOOKUP_VAL | MG | Extendable Lookup |
F1_EXT_LOOKUP_VAL_CHAR | MG | Extendable Lookup Characteristics |
F1_EXT_LOOKUP_VAL_L | MG | Extendable Lookup Language |
F1_FILE_INT_REC | MG | File Integration Record Table |
F1_FILE_INT_REC_ALG | MG | File Integration Record Algorithm Table |
F1_FILE_INT_REC_L | MG | File Integration Record Language Table |
F1_FILE_INT_TYPE | MG | File Integration Type |
F1_FILE_INT_TYPE_L | MG | File Integration Language Table |
F1_INSTALLATION | KP | Installation Option - Framework |
F1_IWS_ANN | MG | Web Service Annotation |
F1_IWS_ANN_L | MG | Web Service Annotation Language |
F1_IWS_ANN_PARM | MG | Web Service Annotation Parameter |
F1_IWS_ANN_TYPE | MG | Web Service Annotation Type |
F1_IWS_ANN_TYPE_L | MG | Web Service Annotation Type Language |
F1_IWS_ANN_TYPE_PARM | MG | Web Service Annotation Type Parm |
F1_IWS_ANN_TYPE_PARM_L | MG | Web Service Annotation Type Parameter Language |
F1_IWS_SVC | MG | Inbound Web Service |
F1_IWS_SVC_L | MG | Inbound Web Service Language |
F1_IWS_SVC_OPER | MG | Inbound Web Service Operations |
F1_IWS_SVC_OPER_PARM | MG | Inbound Web Service Operations Parameter |
F1_LGCY_OBJ | RF | Unsupported Metadata |
F1_MANAG_CONTENT | MG | Managed Content |
F1_MANAG_CONTENT_L | MG | Managed Content Language |
F1_MAP | MG | UI Map |
F1_MAP_L | MG | UI Map Language |
F1_MD_BI_TBL | MG | MD Table for BI |
F1_MD_BI_TBL_FLD | MG | MD Field Table for BI |
F1_MD_BI_TBL_L | MG | MD Language Table for BI |
F1_MIGR_PLAN | MG | Migration Plan |
F1_MIGR_PLAN_INSTR | MG | Migration Plan Instruction |
F1_MIGR_PLAN_INSTR_ALG | MG | Migration Plan Instruction Algorithm |
F1_MIGR_PLAN_INSTR_L | MG | Migration Plan Instruction Language |
F1_MIGR_PLAN_L | MG | Migration Plan Language |
F1_MIGR_REQ | MG | Migration Request |
F1_MIGR_REQ_INCL_REQ | MG | Migration Request Grouping |
F1_MIGR_REQ_INSTR | MG | Migration Request Instruction |
F1_MIGR_REQ_INSTR_ENTITY | MG | Migration Request Instruction Entity |
F1_MIGR_REQ_INSTR_L | MG | Migration Request Instruction Language |
F1_MIGR_REQ_L | MG | Migration Request Language |
F1_MKTCFG | MG | Market Configuration |
F1_OUTMSG_TYPE | MG | Outbound Message Type |
F1_OUTMSG_TYPE_L | MG | Outbound Message Type Language |
F1_PROC_DEFN | MG | Process Flow Type |
F1_PROC_DEFN_L | MG | Process Flow Type Language |
F1_PROC_NEXT_PANEL | MG | Next Panel |
F1_PROC_PANEL | MG | Process Panels |
F1_SCHEMA | MG | Schema |
F1_WEB_CAT | MG | Web Service Category |
F1_WEB_CAT_INCL_SVC | MG | Web Service Category Included Services |
F1_WEB_CAT_L | MG | Web Service Category Language |
SC_ACCESS_CNTL | MG | User Group Access Control |
SC_APP_SERVICE | MG | Application Service |
SC_APP_SERVICE_L | MG | Application Service Language |
SC_USER | KP | User |
SC_USER_CHAR | KP | User Characteristic |
SC_USER_GROUP | KP | User Group |
SC_USER_GROUP_L | KP | User Group Language |
SC_USR_GRP_PROF | MG | User Group Profile |
SC_USR_GRP_USR | KP | User Group User |
