Archive Partition
1. Make the tablespace to be archived READ ONLY.
ALTER TABLESPACE CM_XT039_P2017JAN READ ONLY;
2. Check the feasibility of archive using ILM_ARCH_SW = ‘N’.
Select count(1) from CISADM.CI_TD_ENTRY PARTITION P2017JAN where ILM_ARCH_SW = ‘N’;
If Yes (count of records of above query is ZERO), then proceed for further steps.
If No (count of records of above query is Non ZERO), then make the tablespace back to READ WRITE MODE as Archive is not Feasible at the time.
ALTER TABLESPACE CM_XT039_P2017JAN READ WRITE;
3. Create separate archive tablespace for partition need to be archived.
CREATE BIGFILE TABLESPACE CM_XT039_P2017JAN_ARC DATAFILE '+DATA' SIZE 50M AUTOEXTEND ON MAXSIZE UNLIMITED DEFAULT ROW STORE COMPRESS ADVANCED;
4. Create staging tables and load data for all child tables for the MO first.
a. CI_TD_ENTRY_CHA
CREATE TABLE CM_XT701_P2017JAN_ARC PARALLEL NOLOGGING TABLESPACE CM_XT039_P2017JAN_ARC
AS
SELECT /*+ PARALLEL */ * FROM CISADM.CI_TD_ENTRY_CHA PARTITION (P2017JAN_S01)
UNION ALL
SELECT /*+ PARALLEL */ * FROM CI_TD_ENTRY_CHA PARTITION (P2017JAN_S02)
UNION ALL
UNION ALL
SELECT /*+ PARALLEL */ * FROM CI_TD_ENTRY_CHA PARTITION (P2017JAN_S08)
ALTER TABLE CM_XT701_P2017JAN_ARC NOPARALLEL LOGGING;
b. CI_TD_MSG_PARM
CREATE TABLE CM_XT04_P2017JAN_ARC PARALLEL NOLOGGING TABLESPACE CM_XT039_P2017JAN_ARC
AS
SELECT /*+ PARALLEL */ * FROM CISADM.CI_TD_MSG_PARM PARTITION (P2017JAN_S01)
UNION ALL
SELECT /*+ PARALLEL */ * FROM CI_TD_MSG_PARM PARTITION (P2017JAN_S02)
UNION ALL
UNION ALL
SELECT /*+ PARALLEL */ * FROM CI_TD_MSG_PARM PARTITION (P2017JAN_S08)
ALTER TABLE CM_XT04_P2017JAN_ARC NOPARALLEL LOGGING;
c. CI_TD_LOG
CREATE TABLE CM_XT721_P2017JAN_ARC PARALLEL NOLOGGING TABLESPACE CM_XT039_P2017JAN_ARC
AS
SELECT /*+ PARALLEL */ * FROM CISADM.CI_TD_LOG PARTITION (P2017JAN_S01)
UNION ALL
SELECT /*+ PARALLEL */ * FROM CI_TD_LOG PARTITION (P2017JAN_S02)
UNION ALL
UNION ALL
SELECT /*+ PARALLEL */ * FROM CI_TD_LOG PARTITION (P2017JAN_S08)
ALTER TABLE CM_XT721_P2017JAN_ARC NOPARALLEL LOGGING;
d. CI_TD_SRTKEY
CREATE TABLE CM_XT041_P2017JAN_ARC PARALLEL NOLOGGING TABLESPACE CM_XT039_P2017JAN_ARC
AS
SELECT /*+ PARALLEL */ * FROM CISADM.CI_TD_SRTKEY PARTITION (P2017JAN_S01)
UNION ALL
SELECT /*+ PARALLEL */ * FROM CI_TD_SRTKEY PARTITION (P2017JAN_S02)
UNION ALL
UNION ALL
SELECT /*+ PARALLEL */ * FROM CI_TD_SRTKEY PARTITION (P2017JAN_S08)
ALTER TABLE CM_XT041_P2017JAN_ARC NOPARALLEL LOGGING;
e. CI_TD_DRLKEY
CREATE TABLE CM_XT037_P2017JAN_ARC PARALLEL NOLOGGING TABLESPACE CM_XT039_P2017JAN_ARC
AS
SELECT /*+ PARALLEL */ * FROM CISADM.CI_TD_DRLKEY PARTITION (P2017JAN_S01)
UNION ALL
SELECT /*+ PARALLEL */ * FROM CISADM.CI_TD_DRLKEY PARTITION (P2017JAN_S02)
UNION ALL
UNION ALL
SELECT /*+ PARALLEL */ * FROM CISADM.CI_TD_DRLKEY PARTITION (P2017JAN_S08)
ALTER TABLE CM_XT037_P2017JAN_ARC NOPARALLEL LOGGING;
5. Create staging table and load data for parent table.
CREATE TABLE CM_XT039_P2017JAN_ARC NOLOGGING PARALLEL TABLESPACE CM_XT039_P2017JAN_ARC AS
SELECT /*+ PARALLEL */ * FROM CISADM.CI_TD_ENTRY PARTITION (P2017JAN);
ALTER TABLE CM_XT039_P2017JAN_ARC NOPARALLEL LOGGING;
6. Export tablespace using TRANSPORT_TABLESPACES method.
ALTER TABLESPACE CM_XT039_P2017JAN_ARC READ ONLY;
expdp system/manager DIRECTORY=DUMP_DIR DUMPFILE= CM_XT039_P2017JAN_ARC.DMP TRANSPORT_TABLESPACES = CM_XT039_P2017JAN_ARC LOGFILE=EXP_ CM_XT039_P2017JAN_ARC.LOG TRANSPORT_FULL_CHECK=Y
Ensure tablespace datafile required for further import should be preserved.
<<Transport THE FILE to LOCAL DB DIRECTORY DUMP_DIR like connected to asmcmd and copied the file from cp cm_xt039_p201701_tbs_ar.553.913864937 /tugbu_perf_02/BACKUPS/test_verification/ >>
7. Drop the partition, partition tablespace and archive tablespace (as it is already exported).
ALTER TABLE CISADM.CI_TD_ENTRY DROP PARTITION P2017JAN UPDATE INDEXES;
DROP TABLESPACE CM_XT039_P2017JAN INCLUDING CONTENTS AND DATAFILES;
DROP TABLESPACE CM_XT039_P2017JAN_ARC INCLUDING CONTENTS AND DATAFILES;
