Bug Number | Description |
Oracle Utilities Customer Care and Billing | |
34469631 | COPY OF 33179411 - ERROR DUE TO SEASONAL ADDRESS 0229 WHEN NOT LEAP YEAR |
34839829 | CCB 29012 MAIN - UNABLE TO TRIGGER PAYMENT RECEIVED NOTIFICATION TASK - NOTIFICATION |
35020313 | CHARACTERISTICS UPDATE ISSUES |
35042857 | BUSINESS FLAG QUERY SHOULD ONLY DISPLAYED OR VISIBLE PER PRODUCT DELIVERY. |
35045930 | PSR_CX4U_22C_POOL2: V-MODEL/COMMUNICATIONSPREFERENCES/ REST CALL TAKES 1.45S |
35046608 | PSR_CX4U_22C_POOL2: V-MODEL/BILLINGCONTEXT/ REST CALL TAKES 1.2 SEC AND SIZE 2.5KB |
35066565 | COPY OF 35001160 - THE NBB RECOMMENDATION RULE IS NOT WORKING AS IT IS REFERRING TO USE THE ALGORITHMS WHICH ARE PLUGGE |
35075687 | COPY OF 34863491 - C1-DSQHCHARACTERISTICVALUE - BASE BUSINESS SERVICE FAILING IN SCRIPT |
35079627 | COPY OF 34044052 - PRECISIONEXCEPTION - CANNOT WRITE STRING FIELD MR_DATA_AREA |
35079653 | COPY OF 34802576 - WHEN COMPLETING ORDER, "ORDER ID XXX ORDER ENTITY MAIL COMBINATION, NOT FOUND" ERROR ISSUED |
35091734 | COPY OF 34976232 - SCALAR READ MORE THAN 9 DIGITS CAUSE AN ERROR DURING BILL GENERATION |
35091775 | COPY OF 34971564 - SST: PERSON IDENTIFIER IS REQUIRED EVEN IF PERSON ID USAGE IN INSTALLATION OPTIONS IS SET TO 'OPTIONAL' |
35108811 | COPY OF 34995301 - SEAMLESS MOVE ORDER SHOULD AUTO-SELECT THE CAMPAIGN ASSOCIATED WITH CIS DIVISION |
35113638 | COPY OF BUG 33645680 - CHARITY ENROLL IS NOT WORKING AS EXPECTED WHEN SELECTED AMOUNT IS IN DECIMAL FORMAT |
35114774 | SEARCHPERSONACCOUNTS AND BUSINESSPERSONQUERIES REST RESPONSE HAD INCONSISTENCY IN THE NUMBER OF BILLING ACCOUNTS |
35120781 | COPY OF 35112871 - INCORRECT URL COMPONENT VALUE FOR CCB CLOUD SERVICE IN HELP LINK CONFIGURATION EXT LOOKUP |
35126321 | COPY OF 34417617 - PROCESS FLOW: UNABLE TO UTILIZE PREVIOUS BUTTON DURING STOP SERVICE |
35138395 | COPY OF 34723321 - UNABLE TO EDIT REGISTRATION POINT CHARACTERISTIC VALUES(PORTAL ZONE-C1-REGPTCHAR) |
35148707 | COPY OF 35148208 - CUSTOMER CONTACT ID NOT PASSED WHEN NAVIGATING FROM TO DO TO CUSTOMER CONTACT |
35158117 | PSR : CXPERSONS CCS REST API TAKING MORE TIME IN CX4UPS ENVIRONMENT |
35162905 | COPY OF 34895167 - PREMISE ID IS NOT AUTO POPULATING IN CASE CHAR SP ID SEARCH OPTION |
35183987 | COPY OF 35132380 - CCB - NEED ABILITY TO EASILY DISPLAY BILLS FROM ORACLE OBJECT STORAGE |
35192840 | COPY OF 35171301 - BILL SEGMENT SYSTEM ERROR: INDEXOUTOFBOUNDSEXCEPTION |
35194063 | COPY OF 34777339 - ¿QUERY TYPE FIELD IS MISSING¿ APPEARS WHILE CLICKING THE ¿GO TO METER/ITEM SEARCH |
35215254 | COPY OF 35145051 - LOADING CI_B_LN_CHAR FAILS USING 2 METHODS |
35215406 | COPY OF 34645250 - MULTI-ITEM CHARGES AN ADDITIONAL DAY WHEN ITEM EXCHANGE DURING PERIOD |
35235810 | COPY OF 34654906 - START/STOP ISSUE WHEN PREMISE HAS HISTORICAL (STOPPED/CLOSED) SERVICES |
35239324 | COPY OF 35190431 - SYSTEM ERROR WHEN SCRIPT X1-MCCBTOUGP PERFORMS " INVOKEBO "$CCBBO" USING "C1-TOUGROUP" FOR REPLACE. |
35241986 | COPY OF 35215068 - RETRIEVAL OF SQ FROM PRIOR CALCULATION HEADER |
35254259 | CXVERIFYACCOUNT READ CALL DOES NOT USE CIS DIVISION SPECIFIC CONFIGURATION FOR IDENTIFIERS |
35258667 | CCS API FOR FINANCIAL HISTORY TAKING HIGHER RESPONSE TIME |
35276324 | COPY OF 34808203 - DSS-SHOW CURRENT DATED SCHEDULED PAYMENTS FOR NON SELF-SERVICE CREATED PAY PLANS |
35280862 | COMMUNICATION PREFERENCE AND MAILING ADDRESS IS HAVING HIGH RESPONSE TIME |
35285938 | COPY OF 34994391 - REDWOOD-TESTING: SOME DETAILS ARE NOT DISPLAYED IN THE REGISTRATION PAGE. |
35295198 | COPY OF 34874598 - PERFORMANCE ISSUE ON A BASE SQL IN SCRIPT C1SSTPERSRCH |
35303299 | COPY OF BUG 35265344 - UPDATE ACCOUNT" API ERROR RESPONSE |
35312729 | CCS API FOR BILLINGCONTEXT IS TAKING HIGHER RESPONSE TIME |
35346896 | COPY OF 34948329 - ISSUE WITH CALC SQ RETRIEVING CHAR VALUE USING CONDITIONAL FORMULAS |
35351714 | COPY OF 35068187 - C1-TDBSER-PR BASE ALGORITHM CAUSING MULTIPLE OPEN TD-BSERR TO DOS |
35351812 | COPY OF 35307045 - NAVIGATION TO SP VIA PREMISE TREE VIEW SP LINK IS INCORRECT ACCORDING TO USER PERMISSIONS |
35351819 | COPY OF 34385034 - ACCOUNT BILL PAYMENT HISTORY SCREEN NOT FILTERING CORRECTLY USING 'UNMATCHED' EVENT |
35351849 | COPY OF 34966423 - TENDER CONTROL CURRENCY CODE - NOT AUTOMATICALLY POPULATED |
35368073 | COPY OF 35106196 - CC&B 2.8 - SEARCH BUTTON IN REGISTER DATA SET PAGE IS NOT WORKING |
35377070 | ADD NEW VALUES TO C1-SQDTTMHIGHLIGHTTYPELOOKUP EXTENDABLE LOOKUP |
35377176 | COPY OF 35073580 - START PROCESS FLOW - ENABLE MASKING ON PRIMARY PERSON IDENTIFIER IN PANEL 2 |
35380642 | COPY OF 35011298 - STOP SERVICE PROCESS FLOW LIMITATION WITH PERSON CHARACTERISTICS |
35395519 | INCORRECT FIELD NAME IN CCS RESPONSE FOR BILLING DETAILS |
35399746 | COPY OF 35006100 - CCB2.9 LOST FUNCTIONALITY OF BILLED CONSUMPTION ZONE TOGGLE BUTTON |
35414927 | COPY OF 35364987 - ALERT SHOWING 1 DAY TO NEXT BILL WHEN INCORRECT |
35435378 | COPY OF 35318494 - NOT ABLE TO SEARCH CHARACTERISTIC VALUE ON CUSTOMER CONTACT |
35462155 | COPY OF BUG 35377606 - NAME SEARCH IN CUSTOMER LIST IS NOT RETURNING EXPECTED RESULTS |
35473104 | COPY OF BUG 35332053 - IWS C1-ACCOUNTDATA RETURNING INCORRECT ARREARS AMOUNTS |
35476097 | COPY OF 35370477 - WEB USER - REFERENTIAL INTEGRITY ERROR DURING SA ACTIVATION |
Oracle Utilities Meter Data Management | |
33647250 | SERVICE ORDER TRENDS DASHBOARD: "UNDEFINED" LEGEND IN ZONES |
34304264 | UOM FILTERING: SSN ODR DOES NOT HAVE DETAILS STATING THAT ALL UOMS FILTERD |
35073460 | COPY OF 35160109 - D3-FPCOMM ATTEMPTS TO CREATE A TO DO WITHOUT A TO DO TYPE |
35110754 | COPY OF BUG 35110742 - COPY OF BUG 35110724 - COPY OF BUG 35088945 - CAN'T LOAD WATER METER READS |
35123701 | COPY OF BUG 34909089 - COPY OF BUG 34909084 - MDM SP PAGE - CANNOT EDIT THE SP WHEN ROUTE CODE IS BEYOND 1000 RECORDS |
35124408 | COPY OF BUG 34118244 - SERVICE POINT DEVICE LOCATION CHANGE NOT CAPTURED IN INITIAL AND FINAL SNAPSHOT. |
35124573 | COPY OF ENH 34880376 - COPY OF ENH 34490267 - MC(BO) - PERIODIC ESTIMATION ALGORITHM SPOT TO HAVE A NEW PARAMETER ESTIMATION DATE |
35124740 | COPY OF BUG 34817952 - COPY OF BUG 34490189 - ALGORITHM USING ALGORITHM TYPE D1-IMD-CRTFD RETURNS SYSTEM ERROR WHEN ELEMENT IS NOT PRESENT |
35129320 | COPY OF BUG 35118950 - COPY OF BUG 35118948 - COPY OF BUG 34166887 - CCB-MSCS INBOUND SYNC REQUEST IN ERROR |
35132582 | COPY OF 35132579 - COPY OF 35132578 - COPY OF 35132576 - COPY OF 35131451 - EXTRACT FILE DOES NOT HAVE HEADERS AFTER PATCH 35028265 |
35155075 | COPY OF BUG 35155065 - COPY OF BUG 35155053 - INDEXOUTOFBOUNDSEXCEPTION THROWN WHEN ESTIMATING INTERVAL MC |
35159253 | COPY OF 35159249 - USAGE RULE IS NOT WORKING AS EXPECTED FOR A USAGE TRANSACTION FALLING ON A DST TIME |
35160766 | COPY OF BUG 35108698 - FIELD ACTIVITY OUTBOUND COMMUNICATION SEND DETAILS POPULATES WRONG SA ID |
35161826 | COPY OF BUG 35047735 - REMOTE DISCONNECTS NOT BEING KICKED OFF HOURLY |
35161921 | COPY OF BUG 35411101 - COPY OF BUG 35148920 - MSRMT UI INFORMATION TEXT SHOWS MSRMT VALUE WITHOUT MULTIPLIER APPLIED |
35162120 | COPY OF 35162117 - COPY OF 35162114 - COPY OF 35162111 - COPY OF 35161195 - DIVIDE BY ZERO EXCEPTION WHEN CALCULATING DEVICE AND CHANNEL COUNT SNAPSHOT |
35167077 | COPY OF 35125024 - DEVICE HISTORY SHOWS SAME BADGE NUMBER ON REMOVED METER IN SERVICE POINT INFORMATION STRING |
35171369 | TYPO IN THE OUTCOME LOOKUP VALUE D1ND (NON-RESPONSIVE DEVI'S'E) |
35184301 | COPY OF BUG 34826908 - TIMEZONE ISSUE FOR NEW DEVICES SYNCED FROM ODM TO MDM IN A MULTI TIMEZONE C2M ENVIRONMENT. |
35213547 | COPY OF BUG 34930223 - CONTINUATION OF ISSUE FIXED IN BUG 33820743 - CONSUMPTIVE SCALAR MC REQUIRING START READ |
35217512 | COPY OF 35217481 - COPY OF 35209002 - SA-SP TO US-SP START DATE TIME SYNC IS INCORRECT WHEN THERE ARE MULTIPLE SPS ON SA |
35217556 | COPY OF BUG 34590015 - DELETING CHARACTERISTIC TYPE CREATING SYSTEM ERROR |
35218093 | COPY OF 35093886 - ADK CIM: MANY INBOUND COMM FIELDS ARE NOT VISIBLE IN EDIT UI |
35218561 | COPY OF BUG 35218555 - COPY OF BUG 35218551 - COPY OF BUG 35162604 - PARAMETER FOR DATE RANGE ON MEASURING COMPONENT 360 VIEW IS AUTOMATICALLY COLLAPSED |
35226069 | UGBUPD-13356 - OBFUSCATE CONTACT |
35226145 | COPY OF BUG 35226137 - COPY OF BUG 35226130 - COPY OF BUG 35048753 - D1-IMDV2 QUERY PERFORMANCE |
35228700 | COPY OF 35228681 - CONCURRENCY ERROR WHILE PROCESSING IMDS FROM DIFFERENT PROCESSES ON PRODUCTION IN NEARLY SAME TIME |
35231531 | COPY OF BUG 35231527 - SERVICE POINT PERFORMANCE ISSUE WHEN LARGE NUMBER OF RECORDS IN MULTI-ITEM SECTION |
35231593 | COPY OF BUG 35231584 - SERVICE POINT DIFFICULT TO EDIT IN UI WHEN THERE IS LARGE NUMBER RECORDS FOR MULTI-ITEM INFORMATION |
35232308 | COPY OF BUG 35232303 - SYSTEM CREATED FUTURE DATED BILL SEGMENT FOR A METERED SERVICE. |
35240958 | COPY OF 35093529 - CONCURRENCY ERROR WHEN SUBMITTING SCALAR ODR WITH NO SCALAR CHANNELS CONFIGURED |
35246005 | COPY OF 35246001 - COPY OF 35245998 - COPY OF 34948826 - MEASUREMENT CYCLE ROUTE SCREEN DOES NOT CLOSE UPON SAVING |
35251205 | UGBUPD-13356 - OBFUSCATE DEVICE |
35267400 | COPY OF 35267394 - SNAPSHOT DOWNLOAD TABLES ARE SHOWING NULL VALUES |
35269632 | UGBUPD-13356 - OBFUSCATE SERVICE POINT |
35270355 | COPY OF 35270343 - UPDATE SENSUS COMPOSITES TO USE 4.12 WSDLS AND XSDS |
35274781 | UGBUPD-13356 - OBFUSCATE USAGE SUBSCRIPTION |
35275781 | COPY OF BUG 35275780 - COPY OF BUG 35275779 - COPY OF BUG 35275775 - COPY OF BUG 35275774 - COPY OF BUG 35275773 - COPY OF BUG 33936966 - REPROCESSED ESTIMATE SCALAR IMDS CREATE BAD MEASURE |
35279977 | COPY OF 35279973 - TO DO MANGEMENT PORTAL NOT LOADING FOR IMD EXCEPTION DETAILS |
35288558 | COPY OF BUG 35288550 - COPY OF BUG 35288539 - PREMISE TREE VIEWS INCORRECT ACCORDING TO USER PERMISSIONS |
35291746 | REMOTE DISCONNECT/CONNECT WITHIN A DISABLE/ENABLE SERVICE IS NOT UPDATING DEVICE ON/OFF HISTORY PROBLEM DESCRIPTION |
35317724 | COPY OF 35317706 - COPY OF 35317697 - COPY OF 35273488 - MDM US SYNCHRONIZATION REQUEST ARE FAILING |
35334047 | COPY OF BUG 35334034 - COPY OF BUG 35334021 - COPY OF BUG 35333189 - DISALLOW DEFAULT IMD COMPRESSION WITHIN THE F1-ILMNC BATCH JOB (IMD MO MUST BE SPECIFICALLY IDENTIFIED IN BATCH SUBMISSI |
35334049 | COPY OF 35334033 - COMPLETION EVENT FAILING ON REMOTE DISCONNECT |
35338048 | COPY OF BUG 35046033 - BACK TO BACK ORCHESTRATOR DATE MISALIGNMENT |
35339584 | COPY OF BUG 35339582 - COPY OF BUG 35339576 - COPY OF BUG 35339570 - COPY OF BUG 34111149 - ISSUES RELATED TO IMD PROCESSING |
35345628 | COPY OF BUG 35345624 - COPY OF BUG 35345621 - COPY OF BUG 35305193 - BILL SEGMENT IS NOT SPLITTING AT MONTH END |
35353260 | COPY OF 35353256 - CREW FIELD IS REQUIRED FOR SP EQUIPMENT REMOVALS |
35354451 | COPY OF 35354444 - COPY OF 35354433 - COPY OF 35360173 - SERVICE POINT SEARCH NOT RETURNING SEARCH RESULTS (MDM) |
35374812 | COPY OF 35374807 - TO DO ENTRY GENERATED BY THE D1-VALIDDCT ALGORITHM IS USING AN INCORRECT DRILL KEY |
35392330 | UPDATE "USAGE GROUP PROCESSOR" BS TO ACCEPT LANGUAGE AND CURRENCY |
35393511 | SENDING AN ODR REQUEST FROM CLOUD ENVIRONMENT TO THE TEST HARNESS AND RECEIVED A SERVER-SENT HTTP STATUS CODE 403: FORBIDDEN ERROR. |
35397166 | COPY OF 35396930 - COPY OF 35365117 - BASE ORACLE LG ADAPTER (D3) DOES NOT INCLUDE METERID ELEMENT |
35404470 | COPY OF BUG 35404463 - COPY OF BUG 35404457 - COPY OF BUG 35382692 - END RANGE OPTION FOR NON-LAST SUBUT APPEARING D2SC INSTEAD OF D2SP |
35406243 | SERVICE ORDER TRENDS DASHBOARD: MISSING LEGENDS ON SOME ZONES |
35406451 | COPY OF BUG 35245921 - SEVERANCE PROCESS CANCELLED BY SYSTEM BUT DOESN'T CANCEL DISCONNECT WARNING |
35415898 | COPY OF BUG 35415889 - COPY OF BUG 35375625 - USAGE SUBSCRIPTION SEARCH BY ADDRESS TAKING LONGER TO RETURN RESULTS |
35435311 | COPY OF BUG 35359092 - DISABLE SERVICE THROWING A NULL POINTER EXCEPTION WHILE EXECUTING ALGORITHM D1-CHKMSMT |
35438443 | COPY OF BUG 35438436 - COPY OF BUG 35438427 - COPY OF BUG 35438409 - COPY OF BUG 35364510 - DATACONNECT EXTRACT TIMEZONE OFFSET NOT CORRECT |
35448456 | OUMDM-32067 PROGRAM SUPPORT FOR EVENT SETTLEMENT CALCULATION GROUP NEW (MDM) |
35462621 | COPY OF BUG 35462610 - COPY OF BUG 35016286 - INITIAL MEASUREMENT DATA DISPLAY ISSUE |
35466441 | COPY OF BUG 35450479 - BILL IS IN SYSTEM ERROR FAILING WHEN THERE IS METER EXCHANGE |
35470418 | COPY OF 35470410 - DATA CONNECT BATCH JOB PERFORMANCE VERY SLOW |
35471614 | COPY OF BUG 35471611 - COPY OF BUG 35471606 - COPY OF BUG 35370269 - USAGE TRANSACTION IS IN SYSTEM ERROR |
35475489 | COPY OF BUG 35363524 - EFFECTIVE DATE DISCONNECT SET TO END OF NEXT BUSINESS DATE INSTEAD OF BEGINNING |
35475587 | COPY OF 35475559 - CONNECTDISCONNECT NOT OBFUSCATING PWD IN MSGLOGGING/DIAGNOSTIC.LOG |
35477607 | COPY OF BUG 35477601 - USAGE TRANSACTION SEARCH BY ADDRESS GIVES TRANSACTION TIMED OUT ERROR MESSAGE |
35480720 | COPY OF BUG 35403306 - REMOTE DISCONNECTS NOT BEING KICKED OFF HOURLY |
35482510 | COPY OF 35435588 - STANDALONE MC - LAST HOUR MEASUREMENTS NOT CONSIDERED IN VECTOR & SERVICE QUANTITY MATH USAGE RULE |
35490318 | COPY OF BUG 35383659 - DEVICE SEARCH NOT POPULATING WHEN COMPLETING EXCHANGE METER IN CCS |
35497203 | COPY OF 35400657 - CANNOT ASSESS OBJECT STORAGE VIRTUAL FOLDERS FROM CCS |
35500909 | DEPRECATE F1-ILMAD - ILM AUTOMATION - ADD PARTITION |
Oracle Utilities Work and Asset Management | |
29678459 | DISABLE AUTO-QUERY ON THE PROJECT CUSTOM QUERY IN ALL LOCATIONS WHERE IT EXISTS |
30264805 | CANNOT SELECT SERVICE CALL AS OWNING OBJECT FOR LINKED ATTACHMENTS |
34680815 | VALIDATION ERROR IF BOTH CONSTRUCTION LOCATION OR DESIGN ELEMENT UPDATED ON CWA CU LIST |
34696554 | ERROR ON LOCATION TAB WHEN SAME CU IS EMBEDDED ON MULTIPLE SELECTED CU |
34698563 | WORK REQUEST INITIATED BY FIELD HAS AN INCORRECT/UNEXPECTED HTML TAGS |
34827806 | REMOVE CASE SENSITIVE IN TEMPLATE WORK ORDER QUERY |
34849105 | [INFO] SERVICE CALL RELATED DOCUMENTS ORDER IN 2.4 |
34924510 | PRINTING WORK ORDERS DISPLAYS WO DETAILED DESCRIPTION FOR THE WORK ACTIVITY |
35000422 | INVOICE AUTO-CREATE PROMPTS "INVOICE NUMBER ALREADY EXISTS FOR THE VENDOR LOCATION" FOR REVISED PO |
35006219 | INVOICE LINE NOT DISPLAYED WHEN A TODO IS CREATED AGAINST THE INVOICE |
35017332 | CANNOT CREATE A PO REVISION WITH MUTLITPLE LINE ITEMS WHEN ONE OF THE LINE ITEMS IS IN CLOSED STATUS |
35043597 | WAM - BUSINESS FLAG QUERY SHOULD ONLY DISPLAYED OR VISIBLE PER PRODUCT DELIVERY. |
35060457 | WORK ACTIVITY: COMPLETION TAB ASSET LIST TABLE DOESNT SHOW ASSET LOCATIONS WITHOUT ASSETS. |
35064849 | PLANNED ASSETS NOT ALWAYS DELETED WHEN CU OR LOCATION DELETED FROM THE CWA LOCATIONS TAB |
35073855 | REORDER REVIEW W1-BSRR BATCH FAILS DUE TO STOCK ITEM TO BLANKET CONTRACT MANUFACTURER VALIDATION. |
35075601 | COPY OF 34867885 - MATERIAL RETURN QUANTITY ISSUE |
35077693 | <FIXED AND REVERTED> WORK ACTIVITY : USER UNABLE TO CANCEL WORK ACTIVITY WHEN THERE IS CHANGE IN ASSET / ASSET LIST COMBINATION |
35085173 | CONSTRUCTION LOCATION DETAILS - REMOVE ASSET DIALOG |
35089885 | ADD ASSET DIALOG TAKES TOO LONG TO DISPLAY LOCATION FIELDS |
35116316 | COPY OF BUG 34800943 - ON DEMAND QUANTITY NOT ACCURATE UNDER INVENTORY DETAILS FOR TRACKED ASSETS |
35130210 | COPY OF 35015338 - UNABLE TO EDIT TIMESHEET DETAIL LINE DATE WHEN IN EDIT OR AFTER DUPLICATE |
35199474 | 23A WACS ERP INTEGRATION ISSUES |
35206054 | ERROR WHEN TRY TO ADD CU TO WORK DESIGN AFTER BEING ON DESIGN ELEMENT |
35231524 | COPY OF 34918198 - NO ERROR DISPLAYED WHEN AN ASSET ATTRIBUTE IS UPDATED BUT FAILS VALIDATION |
35248558 | COPY OF 34955258 - TREEVIEW NO LONGER OPENS TO THE LEVEL WHERE THE ASSET OR LOCATION IS |
35272106 | COPY OF 35195748 - ASSET ORIGIN DATE IS EDITABLE WHEN CREATING AN ASSET BUT ALWAYS AUTOMATICALLY SETS TO SYSTEM DATE |
35276835 | COPY OF 35115389 - WACS OUTBOUND MESSAGE DEPENDENCY LIST CONTAINS WAM ID INSTEAD OF OFS ID |
35291977 | W1REPSHB BATCH CONTROL APPLICATION SERVICE SHOULD HAVE WAM_SERVICES USER GROUP INSTEAD OF ALL_SERVICES. |
35298026 | NOT ABLE TO VIEW OUT OF SERVICE LOCATION DROPDOWN WHEN CREATING AN ASSET WITH ASSET TYPE WITH BOTH VALID ASSET LOCATION TYPES AND OUT OF SERVICE LOCATION TYPES |
35307879 | COPY OF 35180578 - ACTIVITY RECONCILIATION PROPERTY UNIT ALLOCATIONS USE THE EMBEDDED CU WITH PROPERTY UNIT CALCUALTED PRICE |
35311250 | OBSERVATIONS IN TIMESHEET DETAILS SCREEN |
35330015 | PHYSICAL INVENTORY ALLOWS NEGATIVE ENTRIES |
35336051 | COPY OF 35328690 - ASSET SPECIFICATION DETAILS NOT GETTING RETRIEVED IN CCS STAGE APPLICATION -STAGING SCHEMA |
35339211 | DOTHAN - WACS DEV - MISSING RECORDS IN F1_EXT_LOOKUP_VAL AND F1_EXT_LOOKUP_VAL_CHAR TABLES FOR BO W2-KEY |
35349238 | COPY OF 35233326 - ASSET SYNC LOG SECTION MISSING IN THE LOG TAB AFTER 22B PATCH UPGRADE |
35367299 | COPY OF 35164976 - SEVERAL BASE OUAV VISUALIZATIONS ARE NOT DISPLAYING CORRECLTY |
35422392 | DUPLICATE ASSETLOCATIONASSETLIST ITEM IS CREATED FOR CWA |
35430499 | COPY OF 35346526 - PHYSICAL INVENTORY ISSUE: STOCK ITEMS DUPLICATE AMONGST DIFFERENT REPORTS |
35439752 | COPY OF 35386283 - WORK ACTIVITY ASSET ATTACHMENT HAS ISSUE ON THE VIEW BUTTON |
35454234 | COPY OF BUG 35348572 - WORK ORDER APPROVAL FAILS WHEN THE UNIT PRICE OF MISC RESOURCE IS ALTERED |
35455575 | UNABLE TO APPROVE CWO |
35473183 | COPY OF 35208736 - ERROR ENCOUNTERED WHILE ASSET DELETION |
Oracle Utilities Customer to Meter | |
34816290 | CROSS INSTALLED METER: UNABLE TO RE-CALC OCBG DUE TO ERROR APPEARS IN BILL CORRECTION PROCESS |
35099057 | DACS - METERED SPS HAVE ADDRESS FIELDS NOT ALIGNED ON MAINT UI |
35099067 | DACS METERED SP DOESN'T HAVE ZONE TO DISPLAYS LINKED DLS |
35099079 | DACS - METERED SPS MAINT UI ISSUES - EXTRA ELEMENTS AND THE FIELD STATE => INVALID VALUE |
35107981 | UPGRADE SCRIPT TO SET THE CORRECT APPLICATION SERVICE ON THE EVENT PARTICIPATION ERROR BO |
35110239 | OVERRIDE BY DIVISION HEADER IS NOT DISPLAYED ON DIGITAL ASSET INTEGRATION MASTER CONFIGURATION MAINTENANCE UI |
35110316 | PROGRAM SUBSCRIPTION MUST BE CREATED IN PENDING DURING PROGRAM ENROLLMENT |
35110386 | WHILE CREATING UNENROLL SERVICE TASK POPULATE DETAILS TO THE LOCATION AND CUSTOMER INFORMATION SECTIONS |
35118332 | COPY OF 35118326 - COPY OF 35118324 - COPY OF 35118047 - SR 3-31331551541: X1-MIGP POPULATES INCORRECT CREATE DATE TIME VALUE FOR PERSONS HAVING MULTIPLE MAIN ACCOUNTS |
35124450 | COPY OF BUG 35109537 - X1-MIGFA BATCH IS NOT CREATING OUC2M SERVICE PROVIDER AS ACTIVITY'S RELATED OBJECT (D1RQ) |
35127472 | DACS-DATARAKER ENROLLMENT SYNC FILE - REMOVE QUOTES IN THE RECORDS |
35131759 | [DACS] X1CI DEVICE IDENTIFIER SHOULD BE REMOVED FROM CTRL DEVICE/ASSET IN 23B |
35142995 | COPY OF BUG 35108637 - 22B X1-DEMNAPNTS ERROR ON A PASS-THROUGH ACTIVITY |
35145870 | COPY OF 35145866 - COPY OF 35145843 - COPY OF 34799320 - FULL CONTEXT ZONE ON DASHBOARD IS SHOWING A SP THAT IS NOT LINKED TO CURRENT ACCOUNT BEING VIEWED |
35188446 | COPY OF 35092764 - ADD AN INITIAL STATE OF "PENDING" TO PROGRAM SUBSCRIPTION LIFECYCLE |
35202379 | OUMDM-31170 EVENT SETTLEMENT CALCULATION GROUP AND PORTAL |
35236391 | OUMDM-31348 EVENT SETTLEMENT TRANSACTION BUSINESS OBJECT |
35252433 | COPY OF 35117356 - BCS - INVALID OWNER_FLG IN LOOKUP |
35266840 | COPY OF 35207323 - FIELD ACTIVITIES BROKEN IN CCS, CCB FA CREATED BUT NOT SOM ACTIVITY |
35280720 | COPY OF 35280714 - COPY OF 35280708 - COPY OF 35280677 - COPY OF 35047479 - ERROR MESSAGE NOT DISPLAYED WHILE ADDING SP CHARACTERISTICS |
35281221 | COPY OF BUG 35258981 - ACTIVITY STATE TRANSITION ERROR: X1-DEMNAPNTS. WX-SELFSERVICEINTEGRATION NOT FOUND |
35333618 | UGBUPD-13606- DACS-NMS EVENT STATUS CHANGE |
35339411 | COPY OF BUG 35339402 - COPY OF BUG 35113077 - NO UPGRADE SCRIPT WAS PROVIDED FOR DEPRECATED X1-XSDUSAGETRANOUTBOUNDMSG FROM BUG 34511968 |
35343474 | CTM-11781 PROGRAM SUBSCRIPTION SUPPORT FOR EVENT SETTLEMENT |
35365100 | OUMDM-31859 OPEN UP UOM/TOU/SQI IN DACS |
35379439 | OUMDM-31939 SERVICE TYPE NAVIGATION |
35387393 | OUMDM-31916 EVENT SETTLEMENT APPLY ALGORITHM AND SYSTEM EVENT |
35404781 | COPY OF 35404777 - C2M CHANGES: CREW FIELD IS REQUIRED FOR SP EQUIPMENT REMOVALS |
35410816 | FIX PRICE SOURCE ISSUES IN EVENT SETTLEMENT CALCULATION RULE BO |
35411722 | EVENT SETTLEMENT CALCULATION RULE BO AND ITS DISPLAY AND MAINTENANCE UI |
35416548 | NAVIGATING TO THE WRONG PORTAL SETTLEMENT CALCULATION RULE QUERY AFTER DELETING EVENT SETTLEMENT CALCULATION RULE |
35420941 | COPY OF 35420934 - COPY OF 35420919 - COPY OF 35419123 - HE BO OPTION VALUE FOR X1D-SERVICEPOINT BO IS INCORRECT |
35444749 | EVT STTL CALC RULE - CODE REGRESSION - INCORRECT DISPLAY/MAIN UI BEHAVIOR FOR NAVIGATION AND DUPLICATE. |
35451399 | COPY OF 35427087 - NAVIGATION TO SP VIA PREMISE CONTEXT MENU IS INCORRECT ACCORDING TO USER PERMISSIONS |
35464463 | OUMDM-32246 PROGRAM SUPPORT FOR EVENT SETTLEMENT CALCULATION GROUP NEW (C2M) |
35484466 | OUMDM-32269 ADD SERVICE AREA COLUMN TO METERED SP AND DEVICE LOCATION BOS |
35484481 | OUMDM-32418 ENABLE FIELD INFO ON METERED SP BO |
35484493 | CTM-10629 RELATED PROGRAM TYPE |
35497710 | COPY OF 35396041 - WHEN F1-CAGVY IS RUN TO COMPILE ALL GROOVY SCRIPTS, AN ERROR IS ENCOUNTERED. |
35500677 | OUMDM-32095 EVENT SETTLEMENT DISPLAY UI + EDIT UI + BPA |
35509948 | OUMDM-32496 CUSTOMER SETTLEMENT DISPLAY UI + EDIT UI |
35511096 | CUSTOMER SETTLEMENT TRANSACTION |
