Bug Number | Description |
35446435 | COPY OF 35446428 UPGRADE NIMBUS-JOSE-JWT TO ATLEAST 9.22 |
35447399 | COPY OF 35447392 JSON-SMART UPDATE TO AT LEAST 2.4.10 |
35452502 | COPY OF BUG 35139223 - DOWNLOAD LINK FOR BATCH IS NOT SHOWN IN BATCH RUN TREE |
35476129 | COPY OF ENH 34877717 - NEED REST ERROR RESPONSE ELEMENTS CONTROL (4.5.0.1.2 - 23B) |
35491932 | COPY OF BUG 35487178 - REQUEST TO WHITELIST SQL LAG FUNCTION |
35504060 | COPY OF 35503456 - F1-MGDPR GETTING JAVA OUT OF MEMORY ERROR |
35507016 | APACHE COMMONS FILEUPLOAD UPDATE TO 1.5 |
35514102 | COPY OF 35514000 - NO XML ESCAPE METHOD AVAILABLE FOR GROOVY STEP/SCRIPTS |
35522185 | BACKPORT OF OUAF-45191 DEBUG TOOL LOG ENTRIES FILES DEFAULT VALUE IS MISSING |
35533006 | BACKPORT OF OUAF-45352 PAGE TITLE NOT BEING HIDDEN ON C360 |
35560097 | TPW LITE : BATCH IS NOT PROGRESSING WHEN INITIATING IT - NULL POINTER AT BATCHLOGWRITER.GETFILENAME |
35568591 | COPY OF 35568572 - MONITORING BATCH PROBE IS FAILING DUE TO PAST SYSTEM OVERRIDE DATE |
35571904 | PLUGIN DRIVEN BATCH BATCH RUN ANALYTICS SNAPSHOT UPDATE (F1BRANSN) HAS ITS SELECT RECORDS ALGORITHM: F1BTCRSNSR INCORRECTLY REFERENCING SPLADM |
35577985 | GETTING NUMBERFORMATEXCEPTION WHILE RUNNING F1BRANEX BATCH IN SFX |
35586406 | BACKPORT OF OUAF-45309 SUPPORT OGL FRAME WITH CONTENT SECURITY POLICY |
35593566 | COPY OF BUG 35587684 - SQL EXCEPTION ON ALGORITHM - REFERENCES TAB - NEW FEATURE NOT WORKING (4.5.0.1.2 - 23B) |
35599818 | NEXTGEN BATCH : NEW THREAD INSTANCE SHOULD CREATE WHEN THE INTERRUPTION HAPPENS |
35608399 | COPY OF BUG 35372959 - ERROR ENCOUNTERED WHEN ATTEMPTING TO ADD OR UPDATE AN ALGORITHM. (4.5.0.1.2 - 23B) |
35623688 | NEXTGEN BATCH : BATCH RUN IS COMPLETED WHEN SOME THREADS ARE STILL IN-PROGRESS |
35635058 | NEXTGENBATCH : BATCH JOB SHOULD BE CANCELLED INSTEAD OF ENDED WHEN USER CANCEL THE JOB |
35640799 | NEXTGEN BATCH : PRIVILEGED TPW BATCH IS NOT WORKING |
35652549 | F1-FLUSH ALWAYS GOES TO ERROR IN NEW BATCH REACTIVE FRAMEWORK |
