Installation Overview
The installation packages for your Oracle Utilities Application Framework-based application must be downloaded from the Oracle Software Delivery Cloud.
Application server installations are new, you cannot upgrade an existing application server. The database installation can be an initial install or an upgrade install.
Before you proceed with the installation process:
1.	Complete the database installation/upgrade process. Refer to the Oracle Utilities Digital Asset Management Database Administrator’s Guide.
Once the Oracle Utilities Application Framework installation is successfully completed and the framework application environment is created, Oracle Utilities Digital Asset Management can be installed on top of the framework environment.
You can download the installation packages from the Oracle Software Delivery Cloud.
This section describes how to install a working Oracle Utilities Application Framework Server, which can then be further configured manually to allow for production performance levels.
Application server installation packages delivered for this version are multi-platform and are ready to install on any supported platform (as described in).
