Configuring Outbound Messages in External System
External System for Work Location and Asset Outbound Sync
Configure an external system record for the GIS system your company sends messages to. Refer to External System - Main for more information.
Provide an entry for each of the outbound message types associated with the GIS Integration web service category following these guidelines:
Field | Value |
Outbound Message Type | The provided outbound message type |
Processing Method | Real-time |
Message Sender | The corresponding message sender for this type of message |
Date/Time Format | XSD |
JSON Conversion Method | REST: XSL Transformation |
Message XSL | SOAP: W1-CommonGISRequestForSOAP.xslREST: W1-CommonGISRequestForREST.xsl |
Response XSL |
SOAP: W1-CommonGISResponseForSOAP.xsl REST: W1- CommonGISResponseForREST.xsl (for WAM if File System is used for XSL files) REST: W1-CommonGISRespForREST.xsl (for WACS if Managed Content is used for XSL files) |
External System for Asset Inbound Sync and Token Generation
Field | Value |
JSON Conversion Method | XSL Transformation |
Response XSL | W1–GISAssetInbound.xsl |
