Bug Number | Description |
Oracle Utilities Customer Care and Billing | |
33186346 | COPY OF 33040811 - ADJUSTMENT FK REFERENCE IS NOT BEING NAVIGATED CORRECTLY FROM CSR SERVICE LOCATION LOG PORTAL |
35046530 | HELP DELETE DUMMY BASE CONFIGURATION |
35294466 | START SERVICE CUSTOMER SERVICE REQUEST TYPE REQUIRES A START SERVICE ELIGIBILITY SCRIPT |
35400738 | DATA FROM "BUSINESSPERSONQUERIES" AND "SEARCHPERSONACCOUNTS" NOT MATCHING |
35516048 | COPY OF 35310586 - SST: OTHER PERSON IDENTIFIER TYPE IS REQUIRED ON CSR TYPE EVEN IF PERSON ID USAGE IN INSTALLATION OPTIONS IS SET TO 'OPTIONAL' |
35520356 | COPY OF 35317489 - ISSUE IN BILL SEGMENT CALCULATION LINE CHARACTERISTIC CREATION |
35535553 | COPY OF 34987083 - CUSTOMER CONTACT CREATION PAGE TURNING BLANK |
35549196 | COPY OF BUG 35549181 - STOP SERVICE PROCESS FLOW LIMITATION WITH ACCOUNT CHARACTERISTICS |
35549470 | COPY OF 34921623 - ISSUE WITH A USER BEING ASSIGNED TO MULTIPLE CIS DIVISIONS |
35563627 | COPY OF 33836396 - PATCH 32833984 DOESN'T WORK WHEN TESTING IEAND IN EDGE IN IE MODE |
35567516 | COPY OF 35542700 - "SYSTEM ERROR. PLEASE SEE LOGS FOR MORE DETAILS.¿ ON BILL SEGMENT CREATION. |
35592086 | COPY OF 35073122 - DURING START FLOW NEW ACCOUNT WILL DEFAULT TO USING PREMISE AS A MAILING ADDRESS |
35597212 | COPY OF 35477671 - SYSTEM ERROR IN DASHBOARD ALERTS |
35597433 | COPY OF 35447055 - BILLABLE SERVICES STATISTICS SNAPSHOT - GIVING SYNTAX ERROR |
35608429 | COPY OF 35504116 - WRITE OFF PROCESSING NOT HAPPENING FOR NON-BILL SA IN 2.8 |
35612876 | COPY OF 34906221 - ADDING A NEW CHAR TYPE TO SP TYPE CANNOT PROCESS ### ROWS IN LIST SP_TYPE_CHARTYPE WITH MAX SIZE 100 |
35625119 | COPY OF 35594446 - "PERSON ID IS MISSING" IS ENCOUNTERED ON STOP SERVICE REQUEST USING CXPROCESSSTARTSTOPREQUEST |
35636543 | COPY OF 35071059 - START SERVICE REQUEST PROCESS FLOW ERRORS OUT DUE TO AN EXISTING PENDING START |
35638100 | COPY OF 34974682 - HIGH RESPONSE TIME ON START / STOP SERVICE FLOW |
35639075 | COPY OF 35601003 - CUSTOM BATCH (CMCOMBIL) DELIVERED FOR SR 3-33193208391/35436758 NOT PRODUCTION READY AND ISSUE NOT RESOLVED |
35646029 | COPY OF 34987442 - CONTROL CENTRAL - COLUMNS NOT ALIGNED WITH HEADERS |
35656397 | COPY OF 35470220 - GDE: TENDER CONTROL BALANCING SOMETIMES NOT TRACKED BY F1-GEEXO |
35657410 | COPY OF 35357939 - ISSUE IN ONETIME ACH PAYMENT |
35658890 | COPY OF 35121410 - SUB BSEG ERROR DUE TO MISSING MASTER BSEG |
35667046 | COPY OF BUG 35619235 - SOME C1 IWS REST SERVICES ARE INACTIVE IN CUSTOMER ENVIRONMENT (23C) |
35673070 | COPY OF 35464793 - MAXIMUM ESTIMATED BILL SEGMENTS FUNCTIONALITY IS WORKING BUT THERE IS ONLY A GENERIC MESSAGE ON BILL SEGMENT; NO VISIBILITY TO THE CLIENT |
35673415 | COPY OF 35369154 - C1-BILLPRINTRECORD DATA AREA: CONSUMPSUB MAPFIELD=" CONSUM_SUB_FLG" |
35674316 | COPY OF 35348302 - SERVER ENCOUNTERED EXCEPTION OCCURRING WHEN GIVING INVALID BILL ID FOR BILL ID ORASEARCH |
35683439 | COPY OF 34514555 - DASHBOARD NOT UPDATED AND CANNOT CLEAR WHEN LOADING A NEW CUSTOMER USING 360 SEARCH |
35688930 | COPY OF 35134708 - GAS TROUBLE SLOWNESS IN OCI CCB DB |
35695551 | COPY OF 35533600 - CUSTOMER CONTACT QUERY DOES NOT INCLUDE THE "COMMENT" FIELD IN THE SUMMARY STATUS |
35696925 | COPY OF 35401970 - EMAIL ADDRESS NOT BEING PULLED WITH D1-RETCUSINF SCRIPT |
35699269 | COPY OF 35650110 - CSR START: NEW ACCOUNT'S COLLECTION CLASS DEFAULTED INCORRECTLY |
35699826 | COPY OF 35524445 - LINK TO CUSTOMER CONTACT NOT WORKING FROM COLLECTION PROCESS, EVENTS TAB |
35715664 | COPY OF 35064651 - BILL ROUTING NOTIFICATION INSIGHT ISSUE |
35717391 | CCS API FOR FINANCIAL DETAILS TAKING HIGHER RESPONSE TIME |
35724837 | COPY OF 35643565 - FOREIGN KEY VALUE CHAR VALUE IS NOT DISPLAYED IN THE CUSTOMER CONTACT |
35740831 | COPY OF BUG 35603115 - DSS IS REDIRECTING TO OVERVIEW PAGE WHEN WE NAVIGATE TO MANAGE ACCOUNTS PAGE |
35743951 | COPY OF 35743703 - ISSUE ON CANCEL OF PROCESS FLOW AFTER APPLYING BUG 34974682 |
35746029 | COPY OF 33504895 - C1-BLAPY DOES NOT LEVERAGE AUTO PAY ROUTE TYPE OVERRIDE CONTROLS FROM CIS DIVISION |
35746489 | COPY OF 35454496 - CUSTOMER CONTACT LETTER EXTRACT ERROR: MAILING ADDRESS RECORD NOT FOUND |
35751482 | COPY OF 34247711 - NEXT BUTTON ON ACTIVE ACCOUNT SUMMARY ZONE (CONTROL CENTRAL - CUSTOMER INFORMATION) DOES NOT WORK |
35757476 | CHARITY SELF-SERVICE TASK IS NOT REFERRED FROM CIS DIVISION CONFIGURATION |
35758653 | COPY OF 35414637 - PAYMENT NOT CREATED WHEN PAY EVENT ADDED |
35759934 | COPY OF 32421384 - PROBLEM ADDING MORE THAN 10 SERVICE AGREEMENT CHARACTERISTICS AT ONCE |
35760961 | CCB MAIN(23C): MULTIPLE BSEG INSTANCE - REGEN BSEG FROM UT HAS ISSUE |
35762021 | COPY OF 35341810 - CASE PORTAL - THE TRANSITION TO THE CONTACT PERSON FROM THE CONTEXT MENU WORKS INCORRECTLY |
35767994 | COPY OF 35664393 - BCS ACCOUNT CHARACTERISTICS HAS MAX LIMIT OF 99 |
35772781 | COPY OF 35689521 - UNABLE TO MIGRATE CI_PP TABLES |
35772793 | COPY OF 35381538 - ISSUE FOR UPDATING ACCOUNT, CANNOT PROCESS 11 ROWS IN LIST ACCT_APAY WITH MAX SIZE 10 |
35778475 | COPY OF 35761595 - [PROD] CSR (CUSTOMER SERVICE REQUEST PERSON) ERRORS (TIME-OUT) OR SQL ERROR OR TIME-OUT |
35793405 | COPY OF 34938146 - COLLECTIONS- CHANGES NOT TRACKED BY GDE |
35795302 | COPY OF BUG 35790960 - NAME SEARCH IN CUSTOMER LIST IS NOT RETURNING EXPECTED RESULTS - POST 35377606 |
35805467 | COPY OF 35783085 - REQUEST TO INCREASE CALCULATION PROCESSOR CALL COUNT UPPER LIMIT OF 100 |
35806345 | COPY OF 35500305 - CANCELING PENDING START FROM START/STOP PAGE DOES NOT CANCEL PENDING STOP |
35812012 | COPY OF 33314601 - MULTI-QUERY ACCOUNT FINANCIAL HISTORY ZONE NOT DISPLAYING ARREARS DATE(S) CORRECTLY |
35819283 | COPY OF 35718455 - CMA - C1-CALCULATIONRULE MIGRATION PLAN NOT ABLE TO EXTRACT ALGORITHM. |
35824512 | COPY OF 35561954 - USE ORAOPENWINDOWWITHURL TO LAUNCH THE APPLICATION INSTEAD OF SUBMITTING A FORM |
35830960 | COPY OF BUG 34013701 - SELF-SERVICE TASK CONTEXT MENU "GO TO ACCOUNT" DOES NOT POPULATE ACCOUNT ON "ACCOUNT" PAGE |
35833747 | COPY OF 34289239 - AFTER FIX FOR BUG 30847523 - STILL PAYMENT EVENT QUICK ADD NO REDIRECTION TO PAYMENT EVENT |
35841948 | COPY OF 35695153 - NOT ABLE ADD MORE THAN 50 CHARS ON SERVICE POINT |
35849607 | COPY OF BUG 35492447 - AUTOPAY ELIGIBILITY ISSUES |
35853975 | COPY OF 35553699 - BATCH PAYSPR NONZERORETURNCODEEXCEPTION |
35855950 | ILLEGAL ARGUMENT EXCEPTION ON HIBERNATE EVENT DEFAULT EVICT EVENT LISTENER ONEVICT |
35858701 | COPY OF 35798691 - ERROR ENCOUNTERED WHEN RUNNING TD-BSERR WHEN TO DO TYPE HAS CUSTOM TO DO TYPE - TO DO PRE-CREATION |
35860639 | COPY OF 35767350 - BCS BATCH CONTROL BCSBILL(REPLICATE OF BILLING) AND C1-BLACC RUNNING LONG |
35869745 | COPY OF 35696806 - DIFFERENCE IN INITIAL SQ CALCULATION IN RATE CHECK (CORRECT) COMPARED TO BILL SEGMENT (INCORRECT) |
35870835 | COPY OF 35779990 - NEW ISSUE WITH F1-MGOAB NOT ADDRESSED IN BUG 35489955 FOR THE C1-ACCOUNT MIGRATION PLAN |
35877457 | COPY OF 35851435 - BATCH ADM2 TAKES LONGER IN 22C COMPARED TO 22B |
35878401 | INCONSISTENT ORDERING IN THE BILL COMPARISON RESPONSE |
35887471 | COPY OF 34738893 - MULTI-CURRENCY MODE IN CCB 2.9 |
35902587 | COPY OF 35849167 - UNABLE TO POPULATE CK_PP TABLE WITH PRODUCTION KEYS USING BATCH F1-CVASG |
35904803 | COPY OF 34039505 - ADDRESS FIELDS ON THE SST PROCESS FLOWS NOT GETTING DISPLAYED AS PER CONFIGURED LABEL |
35911554 | COPY OF 35685582 - BASE CCS PORTAL "C1_FA_PRTL" DOES NOT LOAD SERVICE ORDER MANAGEMENT INFORMATION SECTION. |
35925040 | ID NUMBER MISSING ERROR WHEN ID ADDED ON PANEL 4 IN PROCESS FLOW 35933694 COPY OF 35436054 - RATE CHECK IS ENCOUNTERING SYSTEM ERROR WHEN RATE SCHEDULE HAS CALCULATE FINAL READING VALUE RULE. |
35933709 | COPY OF 35110877 - WEEKLY PROJECTED CHARGES AND HIGH BILL NOTIFICATION - ISSUE IN BASE C1-CALCPRCHG |
35933899 | COPY OF 35826487 - SYSTEM ERROR ENCOUNTERED NAVIGATING TO A SUB-SA (SA RELATIONSHIP/ADJUSTMENT) |
Oracle Utilities Meter Data Management | |
35131418 | DST ISSUE WHEN DISTRIBUTING UFE IN SETTLEMENT TRANSACTION |
35282884 | COPY OF BUG 35282873 - COPY OF BUG 35282865 - COPY OF BUG 35282855 - COPY OF BUG 35224980 - INCORRECT START READ FOR SECOND PERIOD FOR A UT WITH A DATE BREAK |
35430776 | MTZ SUPPORT FOR SA/US SYNC (MDM) |
35500634 | COPY OF BUG 35500585 - COPY OF BUG 35393505 - SOM-MWM UOM HANDLING NOT ADEQUATE FOR CURRENT MWM AND SOM SCHEMAS |
35507693 | COPY OF 35507690 - PERIODIC ESTIMATION FAILS TO ESTIMATE A FINAL SCALAR READING |
35523939 | METER OPERATIONAL DASHBOARD: "UNDEFINED" LEGEND IN ALL TREND ZONES |
35525501 | COPY OF BUG 35525497 - COPY OF BUG 35524793 - COPY OF BUG 35450445 - CONTRACT OPTION EVENT STATUS IGNORED |
35530579 | COPY OF 35530574 - INTERVAL ESTIMATION IMD GENERATED BY CONSUMPTION SYNC ACTIVITY IS CREATED WITH ONE INTERVAL MISSING |
35535946 | COPY OF BUG 35535941 - COPY OF BUG 35535935 - COPY OF BUG 35535920 - SLOWNESS IN D2-UTCD JOB (BILLING JOB) |
35548778 | COPY OF BUG 35491754 - UPDATE SP COMPLETION EVENT VALIDATION PREVENTS DISCONNECTLOCATION UPDATE IF THAT'S ALL THAT CHANGED |
35550581 | COPY OF 35550577 - COPY OF 35548974 - COPY OF 35446215 - IMD FILTERING BY UOM IS NOT FILTERING -- TO DOS FOR UNKNOWN UOM ARE CREATED |
35557011 | COPY OF BUG 35309073 - FIELD ACTIVITY ENRICHMENT SERVICE FAILED WHEN RETRIEVING READING DETAILS |
35563362 | CONTRACT OPTION EVENT OVERRIDE MUST BE PRORATED ACCORDINGLY |
35567822 | COPY OF BUG 35567820 - COPY OF BUG 35416942 - ESTIMATION FLAG NOT DISPLAYED IN MDM AND CCB |
35571591 | COPY OF 35571588 - COPY OF 35571581 - COPY OF 35571573 - COPY OF 35421425 - F1-ILMNC (ILM AUTOMATION-NONMEASUREMENTCOMPRESSION) BATCH GIVING ERROR CODE 959 |
35571655 | COPY OF 35459146 - COPY OF 35459141 - COPY OF 35459124 - COPY OF 35454536 - D2-TRNUS ASSUMES THAT D1 SP MO ENTRY ALWAYS EXIST IN THE MASTER DATA AND SEEDER SYNC CONFIGURATION (INTERNAL) |
35571882 | THE EXTENDABLE LOOKUP - BUSINESS OBJECT MIGRATION IMPORT PROCESSING ORDER (F1-MIGRIMPORTPROCESSINGORDER) SHOULD BE UPDATED WITH THREE NEW VALUES. |
35572166 | COPY OF BUG 35549528 - COPY OF BUG 35549525 - COPY OF BUG 35549518 - COPY OF BUG 35219611 - MULTI-ITEM MAINTENANCE IS BROKEN WHEN MORE THAN MULTI ITEMS ARE STORED IN SP BO DATA AREA |
35572923 | COPY OF BUG 35231161 - COPY OF BUG 35154189 - COPY OF BUG 34709861 - COPY OF 34579506 - ONGOING IE/SP SYNC GOING TO UPDATE OR PRE-ADD ERROR CREATING PARTIAL IE/SP RECORDS IN THE UI |
35575492 | COPY OF BUG 35575489 - COPY OF BUG 35575480 - COPY OF BUG 35514857 - A NEW BEHAVIOR WITH IMD GENERATED ON REPROCESSING ACTIVITY GENERATED ON INSTALL DATE CHANGE. |
35579460 | COPY OF 35554513 - MDM - DATA CONNECT BATCH JOB PERFORMANCE VERY SLOW |
35592022 | COPY OF BUG 35592019 - COPY OF BUG 35592015 - COPY OF BUG 35592010 - COPY OF BUG 35548598 - D1-IMDV2 INCORRECT MC ORDERING |
35596508 | COPY OF 35592214 - FORTIFY SECURITY: PORTABILITY FLAW: LOCALE DEPENDENT COMPARISON: SPECIALIZEDAGGMEASUREMENTDATAEXTRACTHISTORICALBATCHPROCESS.JAVA:261 - TOUPPERCASE() : CASE CHANGED USING |
35604650 | COPY OF BUG 35398170 - FIELD ACTIVITY ENRICHMENT SERVICE FAILED WHEN RETRIEVING READING DETAILS |
35605551 | COPY OF BUG 35590710 - COPY OF BUG 35585603 - COPY OF BUG 35506255 - TIMELINE ZONE ALGORITHM D2-DVCEVT FOR DEVICE EVENTS STILL EXPECTING DEVICE EVENT RELATED OBJECT |
35616336 | COPY OF 35616299 - COPY OF 35616276 - COPY OF 35601521 - DASHBOARD CURRENT CONTEXT MENU DEFAULTS TO KVARH RECEIVED- DOES NOT UPDATE WITH MC CHANGE |
35616510 | COPY OF 35616493 - COPY OF 35616485 - COPY OF 35616466 - COPY OF 35505840 - F1-ILMMC BATCH FAILURE IN TEST V22B |
35621681 | THE DESCRIPTION OF THE D1-PLPRM PATH-RELATED PARAMETERS NEEDS TO BE CHANGED TO IN SYNCH WITH F1 BASED BATCHES DESCRIPTION. |
35624596 | COPY OF 35624591 - MDM: SETTLEMENT MARKET ADMIN MENU MUST BE RENAMED |
35632117 | COPY OF 35632116 - COPY OF 35632114 - COPY OF 35467861 - DATACONNECT PREMISE EXTRACT NOT CREATING COLUMN HEADINGS |
35637852 | COPY OF BUG 35637732 - DEMAND VALUES MISMATCH WHILE CALCULATING INDIVIDUAL DEMANDS |
35640864 | COPY OF BUG 35640857 - COPY OF BUG 35585605 - UNABLE TO CREATE INTERVAL MEASUREMENT - THE DATE TIME 2023-03-12-02:00:00 IS NOT A VALID LEGAL/WALL TIME FOR TIME ZONE US/PACIFIC- IT IS WITHIN |
35641558 | COPY OF 35641549 - COPY OF 35641546 - COPY OF 35636258 - UGBUPD-14556 ILM - IMPROVE BATCH LOGGING FOR COMPRESSION JOBS |
35650123 | COPY OF 35650101 - COPY OF 35650065 - COPY OF 35595356 - TRANSACTION TIMED OUT - WHILE UPDATING SA/SP |
35653929 | COPY OF 35653924 - SCRIPT D2_ARRAYMATH DOES NOT FIND MARKET CONTRACTS |
35659476 | COPY OF 35659471 - D1_GTT7 AND D1_GTT8 PKS MAKE THEM UNUSABLE AND ADD SECONDARY INDEX |
35660491 | COPY OF BUG 35660489 - COPY OF BUG 35660488 - COPY OF BUG 35464720 - MDM SPECIALIZED DATA EXTRACTS DO NOT SUPPORT ENCRYPTION |
35663096 | COPY OF BUG 35663082 - BILLING CUSTOMER WITH READS FROM ONE DAY AFER BILL DATE/ SA STOP DATE |
35663639 | COPY OF BUG 35549608 - COPY OF BUG 35549602 - COPY OF BUG 35549599 - COPY OF ENH 35348840 - CHANGE REQUIRED FOR THE OBSERVATION RAISED UNDER PATCH 35102984(SR 3-32002211601) |
35664258 | C2M - SA TO US DYNAMIC OPTION DTTMS DON'T REFLECT US/SP/DVC TZ |
35665611 | COPY OF BUG 35665596 - D1-FAREQUESTASYNCHRONOUS ERROR WHEN REQUESTERTRANSACTIONID FIELD IS MISSING |
35666066 | COPY OF BUG 35666058 - COPY OF BUG 35666054 - COPY OF BUG 35470233 - MDM SHOULD NOT OVERRIDE SCALAR FROM INTERVALS IF CONDITION CODE IS LESS THAN SYSTEM ESTIMATE |
35666400 | COPY OF BUG 35666397 - COPY OF BUG 35666392 - COPY OF BUG 34738159 - D1-IMDBE TO DO TYPE CONFIGURATED WITH D1-IMD AS CREATION METHOD THROWING EXCEPTION FOR FINALIZED IMD |
35674040 | COPY OF BUG 35674032 - COPY OF BUG 35669036 - CMA ERROR INSERTING MEASUREMENT THE DATE TIME 2023-03-12-02:00:00 IS NOT A VALID LEGAL/WALL TIME FOR TIME ZONE US/PACIFIC- IT IS WITHIN A "GAP" |
35677857 | COPY OF BUG 35668367 - PASS PARENT ACTIVITY ALGORITHM IS INCORRECTLY INACTIVATED IN D1-FIELDACTIVITY BO IN COMPLETED STATE |
35683745 | COPY OF 35664827 - MV90 PULSE MULTIPLIER FOR OSB ADAPTER |
35685129 | COPY OF BUG 35685123 - COPY OF BUG 35685118 - COPY OF BUG 35444279 - D1-IMD - NEW SQL "1PVW93FD6FGHF" HIGH GETS PER EXECUTION IS IMPACTING SPECINT AND PERFORMANCE OF BATCH |
35702762 | COPY OF 35702748 - D1-ACTVY BATCH CONTROL IS TRIGGERING NUMEROUS OB COMMUNICATIONS TO SSN/AMM HES |
35714424 | COPY OF 35714412 - SETTLEMENT TRANSACTION UI FAILS WHEN BATCH RUN IS ASSOCIATED TO CALCULATIONG GROUP DETAILS |
35719979 | PROVIDE CONFIGURATION SWITCH FOR SSN JMS RESPONSE |
35721429 | COPY OF BUG 35707857 - MDM DEVICE 360 SCALAR READINGS ZONE INCORRECT PRECISION |
35722303 | COPY OF BUG 35722293 - COPY OF BUG 35722287 - COPY OF BUG 35710922 - 22C SYNC - DEVICE SYNC FROM MSCS TO CCB NOT SENDING POSITIVE ACK DUE TO BASE INACTIVE ALGORITHM D1-CRPOSACKM IN 22C |
35723455 | COPY OF 35723451 - COPY OF 35723446 - COPY OF 35261921 - NO HEADER IS BEING CREATED EVEN AFTER APPLYING PATCHES 35028265, 35131451 AND 35202499 |
35734527 | COPY OF BUG 35244229 - SYSTEM ERROR IN OUTBOUND COMMUNICATION OF BACK TO BACK SERVICE ACTIVITY |
35739114 | COPY OF 35739110 - JAVA ERROR WHEN RUNNING BATCH PROCESS |
35741088 | COPY OF BUG 35617101 - CUSTOMER USES THROTTLE OPEN = ALLOWED ON THE REMOTEDISCONNECT ACTIVITY TYPE. D1-CRWTO NOT WORKING |
35746897 | COPY OF 35746888 - COPY OF 35553315 - CONSUMPTION EXTRACT - UNABLE TO EXTRACT MULTIPLE GEN PROC RECORD |
35747304 | ADD SUPPORT FOR L+G CC 8.4 TO SGG NATIVE COMPONENTS |
35754129 | COPY OF BUG 35754122 - INFO BUG - DUPLICATE BUTTON ON A VEE RULE ISN'T FUNCTIONING CORRECTLY |
35757330 | COPY OF BUG 35750232 - MDM ACTIVITY NOT CANCELLED WHEN SEVERANCE PROCESS IS CANCELLED |
35757331 | ADD SUPPORT FOR L+G CC 8.4 TO SGG SOA COMPONENTS |
35758614 | COPY OF 35758610 - COPY OF 35758604 - COPY OF 35756014 - DURING DST, EVERY NEW IMD ADJACENT TO THE PREVIOUS ONE GENERATES A HISTORICAL CORRECTION WHEN IT SHOULDN'T |
35766210 | COPY OF BUG 35752276 - FUTURE DATED DISABLE SERVICE CREATES REMOTE DISCONNECT WITH EFFECTIVE DATE AT END OF BUSINESS DAY INSTEAD OF START OF BUSINESS DAY |
35797008 | COPY OF 35796998 - COPY OF 35795723 - COPY OF 35795704 - COPY OF 35791805 - BATCH F1-ILMMC SHOULD DROP CTAS TABLES INSTEAD OF RENAMING THEM WITH _DROP |
35802042 | COPY OF BUG 35787110 - SEVERANCE WARNINGS CREATED WITHOUT SEVERANCE PROCESS ACTIVE |
35818675 | UGBUPD-14068 - ILM - CLEAR IMD AND USAGE TRANSACTION CONTROL |
35822711 | COPY OF 35822695 - COPY OF 35822070 - DEVICE TYPES OF ITEM WITH A SUB-CLASS ARE NOT DISPLAYED IN THE DEVICE LIST |
35825215 | COPY OF BUG 35825211 - COPY OF BUG 35825205 - COPY OF BUG 35429829 - SYSTEM ERROR FOR REQUEST TO LOAD SP CONSUMPTION HISTORY IN PROD ENV |
35831373 | COPY OF 35698257 - STORM MODE AGGREGATION DIFFERENTIATES ZIP AND ZIP+4 |
35833020 | COPY OF 35833010 - COPY OF 35778279 - COPY OF 35832811 - ADD MISSING CLEAN-UP CODE IN JAVA TO THE COMPRESSION BATCH JOB SUCH AS MEASUREMENT TRIGGER |
35852773 | COPY OF BUG 35852771 - COPY OF BUG 35837296 - ORA-01882: TIMEZONE REGION NOT FOUND EVEN AFTER PATCH 35742372 |
35859661 | COPY OF 35859634 -- ISSUE DETECTED USING USAGE RULE TO CALCULATE WITH VECTOR CONDITION |
35867812 | COPY OF BUG 35867802 - COPY OF BUG 35729214 - AGGREGATION TESTING |
35871530 | COPY OF BUG 35871527 - COPY OF BUG 35803310 - READ ONLY ACCESS USER IS ABLE TO DO TRANSACTIONS |
35872483 | USAGE TRANSACTION QUERY SPINS AND DOES NOT RETURN ANY RESULTS |
35875313 | COPY OF 35875288 - COPY OF 35768510 - MSCS DATA CONNECT- CONSUMPTION EXTRACT REQUEST RANDOMLY ERRORS OUT |
35877986 | COPY OF 35877978 - DIVISION UNDER USER MISCELLANEOUS INFORMATION IS NOT SHOWING CORRECTLY IN USER PORTAL |
35880827 | COPYOF BUG 35677867 - AFTER PATCH 35491754 D1-UPDATESP NOT UPDATING SP WITH DISCONNECT LOCATION |
35896078 | COPY OF BUG 35870761 - SPECIALIZED DATA EXTRACT ENCRYPTION PRIVATE KEY RING OPTIONAL |
35898143 | COPY OF BUG 35898136 - COPY OF BUG 35738154 - USAGE PERIOD CREATED WITH SAME START AND END DATE/TIME CREATED CAUSING UT ERROR |
35905820 | COPY OF 35905814 - COPY OF 35901273 - TAKES 35 SECONDS TO BILL ACCOUNT WHEN INVOKING THE BO D2-USGTRANSEEDER |
35912077 | COPY OF BUG 35908831 - CANNOT SELECT DEVICE STATUS ON/OFF IN FIELD ACTIVITY MANUAL COMPLETION |
35914690 | COMPLETE THE ENTITY LIFECYCLE FOR THE DELETED/ARCHIVED TODO'S FOR UT/IMD/DEVICE EVENT |
35914722 | COPY OF 35914716 - COPY OF 35914710 - COPY OF 35864653 - COMPLETE THE ACTIVITY FOR THE ARCHIVED TODOS TO CLEAN OUT ORPHAN TODO RECORDS |
35925263 | COPY OF BUG 35889193 - LENS MISSING IN MDM 2.5 SP1 INTERVAL - AUDIT VIEW ZONE |
35944507 | COPY OF 35944480 - COPY OF 35689986 - NON PROD (TEST) ERROR DURING THE COMPRESSION OF MEASUREMENTS (F1-ILMMC) |
Oracle Utilities Work and Asset Management | |
28919817 | FIELDS DO NOT GET CLEARED VIA SYNCS FROM ODM TO MDM |
29797609 | INBOUND COMMUNICATION SHOULD'VE SKIPPED COMPLETION EVENT 'CREATE ANY SERVICE HISTORY - ONLINE ONLY' |
32051169 | DELETE BUTTON IS AVAILABLE IN REORDER REVIEW 'CREATED' STATUS BUT DELETE IS NOT ALLOWED. |
32894290 | MESSAGE DISPLAYED IS NOT CORRECT IN CONTEXT |
34933764 | AVERAGE UNIT OF PRICE NOT CALCULATING CORRECTLY ON INV DETAILS SIDEBAR IN THE STOCK ITEM DETAILS |
35031780 | PHYSICAL INVENTORY ASKS FOR ADJUSTMENT BEFORE RECOUNT |
35118371 | BATCH JOB W1-BSRR IS NOT PROCESSING ALL THE RECORDS AS EXPECTED, NEED BETTER ERROR HANDLING |
35361846 | UNABLE TO CLOSE CWA WHEN RECONCILIATION STOCK ITEM ON CU IS PRESENT MORE THAN ONCE UNDER CU RESOURCES |
35445443 | ASSET CHANGE REQUEST: ERROR THAT BADGE AND SERIAL NUMBERS ARE REQUIRED FOR ASSET WHERE THOSE ARE NOT NORMALLY REQUIRED |
35479846 | OLDEST ASSET RETRIEVED FROM ASSET LOCATION IN GLOBAL CONTEXT INSTEAD OF CURRENT |
35480252 | THERE SHOULD BE NO ASSET IN GLOBAL CONTEXT FOR CONSTRUCTION WORK ACTIVITY |
35491237 | CANNOT SENT OUTBOUND MESSAGE FOR CWA WITH "REMOVE" CU FUNCTION |
35509714 | WACS-OFS INTEGRATION DOES NOT WORK FOR ACTIVITIES WITH DEPENDENCIES |
35527682 | QUICK VIEW BUTTON POPUP DISPLAYS THE WRONG ASSET INFORMATION IN THE POPUP WINDOW |
35532103 | CONTINUATION OF BUG 35077693 -WORK ACTIVITY : USER UNABLE TO CANCEL WORK ACTIVITY WHEN THERE IS CHANGE IN ASSET / ASSET LIST COMBINATION |
35533795 | OBSERVED PERFORMANCE ISSUE WHILE SYNCING 60000+ RECORDS FROM GIS TO WAM |
35538465 | COPY OF 35429431- UNABLE ADD ACTIVITY RESOURSE REQUIREMENT TO CREATE PURCH REQ FROM BLANKET CONTRACT, NO LINES, CATEGORY - CONTRACT PURCHASE AGREEMENT |
35564510 | COPY OF 35447022 - ERROR IN CONNECTED TO ZONE ON GENERAL COMPONENTS |
35570043 | REQUIRED BY DATE IS NOT SENT TO ERP IN ERP TASK OUTBOUND MESSAGE REQUEST |
35575602 | BATCH BSRR NOT GROUPING BLANKET CONTRACT ITEMS ON ONE PO |
35585311 | WORK ACTIVITY CANNED REPORT IS DISPLAYING WRONG DATA IN FIELD LABELED "ASSET" |
35587567 | USER IS NOT ABLE TO UPDATE PROJECT STATE FROM STARTED TO CLOSED FROM IWS |
35617725 | COPY OF 35613157 - REMOVE MIGRATION REQUESTS PREFIXED WITH EC |
35628403 | ASSET NUMBER NOT CLEARED WHEN DUPLICATING ASSET FROM CWA CONSTRUCTION LOCATION TAB |
35646594 | NEW RECORD CAN'T BE CREATED IN ASSET REPLICATION |
35649212 | BLANKET CONTRACT MODULE ALLOWING MORE FUNDS TO BE ISSUED THAN BC LIMIT AMOUNT |
35673529 | POLINES IN POLINE ZONE NOT GETTING DISPLAYED WHEN A PO IS CREATED BY W1-BSRR |
35681202 | USER GETTING ERROR WHEN TRYING TO CLOSE CONSTRUCTION WORK ACTIVITY WITH CAPITAL AND NON CAPITAL COST CENTERS ARE ASSOCIATED WITH IT |
35681931 | COPY OF 35624465 - SUPPRESSION NOT FUNCTIONING IN PREVENTATIVE MAINTENANCE |
35696851 | USER IS GETTING ERROR WHEN TRYING TO START PROJECT WITH FUTURE DATE AS ACTUAL START DATE THROUGH IWS |
35708354 | COPY OF 35577010 - NOT ALLOW THE CREATION OF ACTIVITY RESOURCE REQUIREMENT WHEN THE VENDOR LOCATION IS NOT THE SAME ON THE BLANKET CONTRACT |
35718904 | ISSUE IN CLOSING CWA IF EMBEDDED COMPATIBLE UNIT IS ADDED IN MULTIPLE QUANTITIES. |
35719962 | PROJECT¿S SEARCH BY PROJECT NUMBER FAILS WHEN PROJECT NUMBER HAS A LETTER IN LOWERCASE |
35719991 | DEPRECATE UNUSED FIELD UPDATE_ACTUAL_LBL |
35738917 | WPTG_TSN:TUGBU:522299: STRING TEXT NEEDS TO BE IMPROVED |
35755339 | COPY OF 35629658 - CCS REJECTING OFSC COMPLETION |
35764835 | DACS_OFSC INTEGRATION - A GENERIC ERROR IS SHOWN IN THE UI_ BUT IN THE LOGS THE ERROR IS SPECIFIC |
35777114 | W1-BSRR BATCH GENERATES CONFUSING ERROR MESSAGES TO USERS WHEN REORDER REVIEW HAS 'REORDER SOURCE' VALUE DIFFERENT TO 'PURCHASE REQUESTION BO' IN ALGORITHM -W1-RRCMPL |
35843636 | FORTIFY NULL DEREFERENCE ISSUE (HIGH) |
35885300 | REMOVE DB TRIGGERS ON W1_NODE THAT POPULATE W1_GEOM |
35886446 | COPY OF 35506287 - ERROR WHILE SENDING ACTIVITY OUTBOUND MESSAGE OF DACS WORKACTIVITY TO OFS |
35890376 | COPY OF 35888072 - VALIDATION CHECK TO VERIFY ASSET IS ISSUED TO ACTIVITY IS SKIPPED IN W1GASTDTLBNO IWS |
35894693 | COPY OF 35855568 - MISSING INSERT BATCH FOR W1_CU_USAGE |
35896042 | BC SEARCH RETURNS VENDOR LOCATION ID INSTEAD THE BC HEADER ID |
35896329 | UNABLE TO ACTIVATE A WORK ACTIVITY WITH A "PURCHASED" RESOURCE |
35900884 | DISABLE "SAVE" BUTTON IN PHYSICAL INVENTORY RECOUNT ZONE AFTER THE FIRST CLICK |
35903566 | SERIAL NUMBER IS NOT COMING IN RESPONSE FOR W1-MOBILESTOREROOMINVENTORY SERVICE |
35909608 | RECEIPT HEADER IS NOT MOVING TO "COMPLETED" STATUS WHEN ALL THE ITEMS ARE ACCEPTED(UGBUPD-11980) |
Oracle Utilities Customer to Meter | |
34543066 | INSERTION OF NEW CHAR ROW EVEN WHEN THERE IS NO CHANGE TO THE CHAR ITSELF USING X1D-SERVICEPOINT BO |
34767800 | TO DOS ARE NOT GETTING CREATING WHEN ENROLL/UNENROLL SERVICE TASK MOVES TO VALIDATION/ELIGIBILITY ERROR |
35231121 | COPY OF BUG 34341665 - COPY OF BUG 34341649 - SERVICE POINT CHARACTERISTICS RECORD IS CREATED EVEN THOUGH THE VALUE WAS NOT UPDATED |
35525478 | DACS - SEARCH DOESN'T RETURN EST FOR PROGRAM SUBSCRIPTION OR METERED SP |
35553576 | DESIGN CHANGE - DIGITAL ASSET SERVICE TASK QUERY FILTER VALIDATION |
35560330 | DESIGN CHANGE - ENROLLMENT SERVICE TASK VALIDATION |
35562291 | CUSTOMER SETTLEMENT BO CHANGES |
35571008 | COPY OF BUG 35538854 - USAGETYPED2LOOKUP CLASS NOT FOUND ERROR IS FROM CUSTOMER SETTLEMENT CALCULATION |
35586767 | COPY OF 35543984 - CANCEL REASON SHOULD BE FREE FORM(TEXT): UGBUPD-13606- DACS-NMS EVENT STATUS CHANGE |
35593593 | COPY OF BUG 35593585 - ISSUE -WHILE CONFIGURING ACTIVITY DATA AND ADDING 'ASSET SYSTEM DATA RETRIEVER' |
35606734 | CUSTOMER SETTLEMENT: INCORRECT NUMBER OF EVENT SETTLEMENT BASED ON DATE |
35606746 | CUSTOMER SETTLEMENT: REBILL WITH NO EVENT SETTLEMENT ERROR |
35643218 | COPY OF 35643215 - C2M: MARKET ADMIN MENU IS HIDDEN EVEN WHEN SETTLEMENT IS ACTIVE |
35660814 | DACS CUSTOMER SETTLEMENTS FR ITEMS FOR 23C - PART 1 |
35664094 | COPY OF BUG 35664089 - COPY OF BUG 35341527 - THE BATCH JOB X1-MIGMR RUN COMPLETES BUT WILL NOT PROCESS ALL THE RECORDS DUE TO A JAVA ERROR |
35670554 | COPY OF 35480939 - CHANGE MO AUDIT SYNC ALGORITHMS TO EXIT AND NOT SYNC WHEN TRIGGERED BY CMA |
35677681 | COPY OF 35673184 - C2M - C1-BILLPRINTRECORD DATA AREA: CONSUMPSUB MAPFIELD=" CONSUM_SUB_FLG" |
35697323 | EVENT PARTICIPATION TABLE METADATA SHOULD HAVE DATE TIME FORMAT AS PHYSICAL STANDARD |
35707866 | EVENT SETTLEMENT CREATION GENERATES ERROR WHEN DATA CONTAINING DATES FROM STANDARD (PST) TIME TO LEGAL (DST) TIME |
35720194 | PT RE-CALCULATION GENERATES DIFFERENT RESULTS FROM THE FIRST TIME PT CALCULATION. |
35721418 | COPY OF BUG 35721411 - COPY OF BUG 35721408 - COPY OF BUG 35618528 - UNABLE TO CANCEL WEBSERVICE D1-FAREQUESTASYNCHRONOUS FIELD ACTIVITY IN APPLICATION |
35751587 | CST MISSING LINKS TO CHILD ESTS AND THE USER CANNOT NAVIGATE DIRECTLY TO ESTS.IF THE EST CALCULATION RULE IS NOT CONFIGURED WITH THE DESCRIPTION LINE |
35760408 | ERROR IS NOT THROWN FOR WRONG PAYLOAD IN EVENT OUTCOME FLOW |
35761015 | C2M MAIN(23C): MULTIPLE BSEG INSTANCE - REGEN BSEG FROM UT HAS ISSUE |
35775377 | COPY OF 35775375 - COPY OF 35755350 - X1CPSTSP JOB IS FAILING IN PROD |
35796896 | UGBUPD-14503 - SETTLEMENTS DOWNLOAD |
35797018 | DACS EVENT PARTICIPATION ISSUE: AFTER POSTING OUTCOME (SUCCESS) THE STATUS REMAINS IN PRE-EVENT |
35813177 | COPY OF BUG 35813166 - COPY OF BUG 35813161 - COPY OF BUG 35806508 - ONE HOUR IS ADDED TO THE SP EQUIPMENT ATTACHMENT OR DETATCH DATE/TIME |
35834122 | FUTURE DATE FOR CUSTOMER OWNED CONTROLLABLE DEVICE |
35835671 | COPY OF 35756490 - DACS_OFSC INTEGRATION_ ASSET NOT FOUND ERROR WHEN COMPLETING AN ACTIVITY WITH SERVICE HISTORY IN DACS |
35842492 | COPY OF 35823406 - ADDING A NEW DISCONNECT LOCATION GIVES ERROR |
35862172 | COPY OF BUG 35842626 - MS UPLOAD JOB FAIL WHEN RATESCHEDULES FIELD IS EMPTY IN RECORD |
35862177 | COPY OF BUG 35843101 - CONTACT AND MSP UPLOAD INCORRECTLY CHECKING EXISTENCE OF LS/SL VALUES |
35891674 | UGBUPD-14131 -TROUBLE REPORT SERVICE TASK TYPE |
35891896 | UGBUPD-14131 -TROUBLE REPORT SERVICE TASK |
35915906 | COPY OF 35893215 - ATF1 BUNDLE IMPORT IWS CREATED WITH X1 OWNER |
35916933 | COPY OF 35893951 - ATW1 WEBSERVICES WERE ADDED WITH CM USER WHICH ARE NOT NEEDED |
