Bug Number | Description |
35889785 | COPY OF 35653414 - 5.1 UPGRADE: ISSUE IN CONSTRUCT CREATION SCREEN |
35891993 | COPY OF 35799546 - CANNOT ADD ALGORITHM IN BO STATUS |
35892313 | COPY OF BUG 35892308 - COPY OF BUG 35797177 - UNABLE TO PRINT FROM CUSTOMER 360 PORTAL |
35892629 | COPY OF 35826726 - EMBEDDED HELP DOES NOT DISPLAY CORRECTLY AND CANNOT BE VIEWED |
35902276 | COPY OF 35878578 - ERROR THROWN WHILE CALLING CUSTOM WEBSERVICE WHICH INTERNALLY USES CUSTOM BUSINESS SERVICE AND CUSTOM ZONE. |
35909933 | COPY OF BUG 35916092 - BO OPTIONS EDIT ERROR WHEN "GET OPERATION" OPTION EXISTS |
35920747 | COPY OF BUG 35866087 - MASQUERADE IN CCS THROWS EXCEPTION (4.5.0.1.3 - 23C) |
35950634 | COPY FROM BUG 35885166 - UPDATE INSTALLSF.PLX IN ORDER TO RECREATE AUTOMATICALLY THE PRODUCT/APACHE-ANT DURING PATCH INSTALL |
35957251 | COPY OF BUG 35785306 - ERROR IN ADDING LOG MESSAGE WITH PARAMETER(S) IF THERE IS AN AUDIT ALGORITHM IN CUST CONTACT MO (4.5.0.1.3 (23C)) |
36008746 | UNABLE TO USE FILE ADAPTER : CAUSED BY: ORG.APACHE.HC.CORE5.HTTP.STREAMCLOSEDEXCEPTION: STREAM ALREADY CLOSED |
