Installation and Configuration Worksheets
During the installation and configuration of the application you will need to provide a variety of system values. These worksheets will assist you in providing that information. They should be completed before installing the application framework, as described in the Installing the Application Server Component of Oracle Utilities Application Framework.
Note: Some web application server information will not be available until the software installation steps have been completed as described in the Installing Application Server Prerequisite Software.
Refer to the Server Administration Guide for additional details (default, valid values, usage, etc.), as applicable.
Menu Block 1: Environment ID, Roles, Third Party Software Configuration
The Environment ID, Roles, Third Party Software Configuration options include:
Menu Option
Name Used in Documentation
Customer Install Value
Environment ID
ENVIRONMENT_ID
Server Roles
SERVER_ROLES
Oracle Client Home Directory
ORACLE_CLIENT_HOME
Web Java Home Directory
JAVA_HOME
**ONS JAR Directory
ONS_JAR_DIR
Web Application Server Home Directory
WEB_SERVER_HOME
***Additional JAR Directory
WLTHINT3CLIENT_JAR_DIR
* Denotes optional menu items that may be required for the product installation and variables.
** To activate the RAC FCF, the application needs the external ons.jar file, from the ORACLE_HOME path:
$ORACLE_HOME/opmn/lib/ons.jar
During the installation the relevant option should be populated with the folder location of the ons.jar.
Menu Block 2: Keystore Options
The keystore is a set of files used for encryption, decryption and hash generation. The files reside in the following location:
• <SPLEBASE>/ks/.ouaf_keystore
• <SPLEBASE>/ks/.ouaf_storepass
To run the application correctly, data encryption, decryption and hash generation of data in the database and on the application server must be performed using the same keystore; otherwise, the application will fail.
Starting Oracle Utilities Application Framework v4.4.0.0.0 the keystore and truststore options have been removed from the Menu and defaulted into the following template user exit that is loaded by all the properties files:
templates/FW_spl.properties.keystore.truststore.include
The user can still customize those options using the “Centralized Properties Customization”.
Upgrades from Oracle Utilities Application Framework versions below 4.4.0.0.0 will still use the keystore and truststore options recorded in the existing etc/ENVIRON.INI file (Menu options file).
Note: Populate the “Import Keystore Directory” option to import an existing keystore.
Keystore options include:
Menu Option
Customer
Install
Value
KS_IMPORT_KEYSTORE_FOLDER
Menu Block 50: Environment Installation Options
Environment installation options include:
Menu Option
Customer
Install
Value
Environment Mount Point
SPLDIR
Log File Mount Point
SPLDIROUT
Environment Name
SPLENVIRON
Install Application Javadocs
WEB_ISJAVADOCS
Install Sample CM Source Code
CM_INSTALL_SAMPLE
Menu Block 1: Environment Description
The environment description menu option includes:
Menu Option
DESC
Menu Block 2: [WebLogic] Business Application Server Configuration
WebLogic Business Application Server configuration options include:
Menu Option
Business Server Host
BSN_WLHOST
Business Server Application Name
BSN_APP
Menu Block 3: [WebLogic] Web Application Server Configuration
Refer to Server Administration Guide for additional details (default, valid values, usage, etc.)
WebLogic Web Application Server configuration options include:
Menu Option
Web Server Host
WEB_WLHOST
Weblogic SSL Port Number
WEB_WLSSLPORT
Weblogic Console Port Number
WLS_ADMIN_PORT
Web Context Root
WEB_CONTEXT_ROOT
WebLogic JNDI User ID
WEB_WLSYSUSER
WebLogic JNDI Password
WEB_WLSYSPASS
WebLogic Server Name
WEB_WLS_SVRNAME
Web Server Application Name
WEB_APP
Deploy Javadocs Module
WEB_DEPLOY_JAVADOCS
Enable The Unsecured Health Check Service
WEB_ENABLE_HEALTHCHECK
MDB RunAs User ID
WEB_IWS_MDB_RUNAS_USER
Super User Ids
WEB_IWS_SUPER_USERS
Menu Block 4 - Database Configuration
The parameters below and in the worksheet are for the database configuration. Note that if changes are made to any of the database menu option items below, thus potentially connecting to a different schema, a warning will be displayed in the screen next to the actual option that has been changed.
Menu Option
Customer
Install
Value
Application Server Database User ID
DBUSER
Application Server Database Password
DBPASS
Batch Database User ID
BATCH_DBUSER
Batch Database Password
BATCH_DBPASS
Web JDBC DataSource Name
JDBC_NAME
Database Name
DBNAME
Database Server
DBSERVER
Database Port
DBPORT
ONS Server Configuration
ONSCONFIG
Database Override Connection String
DB_OVERRIDE_CONNECTION
Character Based Database
CHAR_BASED_DB
Oracle Client Character Set NLS_LANG
NLS_LANG
Menu Block 5 - General Configuration Options
The general configuration options include:
Menu Option
Customer
Install
Value
Batch RMI Port
BATCH_RMI_PORT
RMI Port number for JMX Business
BSN_JMX_RMI_PORT_PERFORMANCE
RMI Port number for JMX Web
WEB_JMX_RMI_PORT_PERFORMANCE
JMX Enablement System User ID
BSN_JMX_SYSUSER
JMX Enablement System Password
BSN_JMX_SYSPASS
Coherence Cluster Name
COHERENCE_CLUSTER_NAME
Coherence Cluster Address
COHERENCE_CLUSTER_ADDRESS
Coherence Cluster Port
COHERENCE_CLUSTER_PORT
Coherence Cluster Mode
COHERENCE_CLUSTER_MODE
Menu Block 6 - OUAF TrustStore Options
Refer to the Oracle Utilities Application Framework Server Administration Guide for additional details on this configuration.
Starting Oracle Utilities Application Framework V4.4.0.0.0, the keystore and truststore options have been removed from the Menu and defaulted into the following template user exit that is loaded by all the properties files:
You can still customize those options using the “Centralized Properties Customization” option. Upgrades from Oracle Utilities Application Framework versions below 4.4.0.0.0 will still use the keystore and truststore options recorded in the existing etc/ENVIRON.INI file (Menu options file).
The OUAF truststore configuration is required for IWS.
Menu Option
Customer
Install Value
Import TrustStore Directory
TS_IMPORT_KEYSTORE_FOLDER
Menu Block 8 - OSB Configuration
The OSB configuration includes:
Menu Option
Customer
Install Value
OSB Home
OSB Host Server
OSB Port Number
OSB SSL Port Number
OSB Managed Server Port Number
OSB Managed Server SSL Port Number
JDBC URL for Database
OSB Service Table Schema Name
OSB Service Table Schema Password
OSB WebLogic User Name
OSB WebLogic User Password
Mount Point for OSB Files
/spl/sploutput/osb
Menu Block 9 - SOA Configuration
The SOA configuration includes:
Menu Option
Customer
Install Value
SOA Home
SOA Host Server
SOA Port Number
SOA SSL Port Number
SOA Internal URL
SOA External URL
JDBC URL for SOA Database
SOA Service Table Schema Name
SOA Service Table Schema Password
SOA WebLogic User Name
SOA WebLogic User Password
Specify the Path for XAI/IWS Service
XAIApp/xaiservert
Menu Block 10 - SOA Configuration Plan (MDM)
The SOA configuration plan (MDF) includes:
Menu Option
Customer
Install Value
MDM Bulk Request Callback URL
MDM Headend HTTP Connection Timeout
50000
MDM Headend HTTP Read Timeout
500000
MDM SOA Request Queue JNDI Name
queue/BulkRequestQueue
MDM SOA Notify Queue JNDI Name
queue/BulkNotifyQueue
MDM SOA Command Queue JNDI Name
queue/BulkCommandQueue
SGG-NMS TestHarness Partition Name
SGG-NMS_Test
Menu Block 11 - Configuration for DataRaker Integration
The DataRaker Integration configuration includes:
Menu Option
Customer
Install Value
JNDI Name of Destination Queue to publish SGG payloads for DataRaker Integration Tool
DataRakerQueue
Number of records (SGG Payloads) to accumulate
100
Max file size for the accumulated (SGG Payloads) file in Kilobytes
524288
Specify a time which, when exceeded, causes a new outgoing file to be created in seconds
600
Polling frequency of Staging directory for new files in seconds
60
Mount point/directory for the accumulated SGG payload file
/spl/sploutput/staging
Mount Point/directory for the converted XML file to place for DataRaker
/spl/sploutput/int
Menu Block 16 - SOA Configuration Plan (LG)
The SOA configuration plan (LG) includes:
Menu Option
Customer
Install Value
LG SOA Partition Name
LG
LG SOA TestHarness Partition Name
LG_Test
AMI Event Subscriber Output Path
/spl/sploutput/osb/lg-cim-event
MR_Server endpoint URI
CD_Server endpoint URI
CIM_Server endpoint URI
MeteringServer endpoint URI
Security policy attached to outbound web service calls to a CIM interface
sgg/d3_cfs_cim_header_client_policy
Security policy attached to inbound web service calls from a CIM interface
sgg/d3_cim_token_service_policy
The name of the OWSM policy to use when SOA calls a head end system
oracle/http_basic_auth_over_ssl_client_policy
The name of the OWSM policy to use when SOA is called by a head end system
oracle/http_basic_auth_over_ssl_service_policy
Menu Block 17 - SOA Configuration Plan (NES)
The SOA configuration plan (NES) includes:
Menu Option
Customer
Install Value
NES endpoint URI
SOA partition to which the application is installed
Echelon
Path to the NES EventManager web service on the head end system
CoreServices/EventManager.asmx
Path to the NES GatewayManager web service
CoreServices/GatewayManager.asmx
Path to the NES DeviceManager web service on the head end system
CoreServices/DeviceManager.asmx
Path to the NES SettingManager web service on the head end system
CoreServices/SettingManager.asmx
Path to the NES UserManager web service on the head end system
CoreServices/UserManager.asmx
Name of the OWSM policy to use when SOA calls a head end system
Name of the OWSM policy to use when SOA is called by a head end system
Menu Block 18 - SOA Configuration Plan (Sensus)
The SOA configuration plan (Sensus) includes:
Menu Option
Customer
Install Value
Sensus SOA TestHarness Partition Name
Sensus_Test
Sensus SOA Partition Name
Sensus
MR Server Endpoint URI
CD Server Endpoint URI
OD Server Endpoint URI
Headend Http Read Timeout
500000
Headend Http Connection Timeout
50000
Menu Block 19 - SOA Configuration Plan (SSN)
Menu Option
Customer
Install Value
SSN SOA Partition Name
SSN
SOA Weblogic User Name
SSN SOA Queue JNDI Name
queue/SSNODRQ
SSN Headend DataAggregation Endpoint URI
The URL for the SSN 4.7 DataAggregation service (DataAggregation.asmx)
http://127.0.0.1/CoreServices/DataAggregation.asmx
The URL for the SSN 4.10 DataAggregation service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_1/DataAggregat...
The URL for the SSN 4.14 DataAggregation service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_5_1/DataAggregationPort
The url for the SSN 5.1 DataAggregation service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/DataAggregationPort
SSN Headend DeviceManager Endpoint URI
The URL for the SSN 4.7 DeviceManager service (DeviceManager.asmx)
http://127.0.0.1/CoreServices/DeviceManager.asmx
The URL for the SSN 4.10 DeviceManager service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_1/DeviceManage...
URL for the SSN 5.1/2.7 DeviceManager service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/DeviceManagerPort
URL for the SSN 5.1/2.8 DeviceManager service
https://ssn.ssnsgs.net:3000/amm/ webservice/v2_8/DeviceManagerPort
SSN Headend DeviceResults Endpoint URI
http://127.0.0.1/CoreServices/ DeviceResults.asmx
URL for the SSN 4.7 DeviceResults service (DeviceResults.asmx)
https://ssn.ssnsgs.net:3000/amm/webservice/v2_1/DeviceResult...
The URL for the SSN 4.10 DeviceResults service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/DeviceResults
The URL for the SSN 5.1/2.7 DeviceResults service
The URL for the SSN 5.1/2.8 DeviceResults service
SSN Headend JobManager Endpoint URI
http://127.0.0.1/CoreServices/JobManager.asmx
The URL for the SSN 4.7 JobManager service (JobManager.asmx)
https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/JobManagerPort
The URL for the SSN 4.10 JobManager service
The URL for the SSN 5.1/2.7 JobManager service
The URL for the SSN 5.1/2.8 JobManager service
Menu Block 20 - SSN JMS Source Destination Bridge Configuration
The SSN JMS Source Destination Bridge configuration includes:
Menu Option
SSN Bridge Destination Name
SSNTestHarnessBridgeDestination
SSN Bridge Destination Additional Classpath
SSN Bridge Destination Connection URL
SSN Bridge Destination Initial Context Factory
weblogic.jndi.WLInitialContextFactory
SSN Bridge Connection Factory JNDI Name
jms/SSNTestHarnessConnectionFactory
SSN Bridge Destination Queue JNDI Name
queue/SSNTestSSNODRQ
SSN Destination Bridge Username
Menu Block 21 - DG Reference Implementation SOA Configuration
The DG Reference Implementation SOA configuration includes:
Menu Option
Customer
Install Value
DG SOA Partition Name
DG
500000
50000
DG SOA TestHarness Partition Name
DG_Test
Menu Block 22 - SOA Configuration Plan (Itron Openway)
The SOA Configuration Plan (Itron Openway) configuration includes:
Menu Option
Customer
Install Value
Itron SOA Partition Name
Itron
500000
50000
DataSubscriberService Output Path
ExceptionSubscriberService Output Path
Itron Headend DataService Endpoint URI
Itron Headend DiagnosticService Endpoint URI
Itron Headend UtilService Endpoint URI
Itron Headend ControlService Endpoint URI
Itron Headend ProvisioningService Endpoint URI
Itron Headend ProvisioningService370 Endpoint URI
Itron Headend ControlService370 Endpoint URI:
Itron SOA TestHarness Partition Name
Itron_Test
Advanced Menu Options
The advanced menu options are not available during installation. These options can be accessed after installation using the following commands:
Linux/UNIX:
$SPLEBASE/bin/configureEnv.sh -a
Windows:
%SPLEBASE%\bin\configureEnv.cmd -a
Menu Block 50 - WebLogic Advanced Environment Miscellaneous Configuration
WebLogic advanced environment miscellaneous configurations include:
Menu Option
Customer Value Install
OUAF DBMS Scheduler User
OUAF_DBMS_SCHEDULER_USER
WebLogic ThreadPoolWorker Enabled
WLS_THEADPOOLWORKERENABLED
Online JVM Batch Server Enabled
BATCHENABLED
Online JVM Batch Number of Threads
BATCHTHREADS
Online JVM Batch Scheduler Daemon Enabled
BATCHDAEMON
Enable Batch Edit Functionality
BATCHEDIT_ENABLED
Batch Online Log Directory
BATCH_ONLINE_LOG_DIR
JDBC Read Timeout
JDBC_TIMEOUT
Enable JMS Global Flush for Batch
ENABLE_JMS_GLOBAL_FLUSH
Add UsernameToken.xml
ADD_USERNAMETOKEN_XML
IWS deployment target
WLS_CLUSTER_NAME
Web Admin Server Host
WEB_ADMIN_SERVER
Split File Size in MB
TEMPSTORAGE_SPLITFILESIZE
GIS Service Running on the same Web Server
GIS
GIS Service URL
GIS_URL
GIS WebLogic System User ID
GIS_WLSYSUSER
GIS WebLogic System Password
GIS_WLSYSPASS
Online Display Software Home
ONLINE_DISPLAY_HOME
Max Queries To Hold In Cache Across All Threads
XQUERIES_TO_CACHE
Seconds Timeout Flush Cache Completely
XQUERY_CACHE_FLUSH_TIMEOUT
Malware Scan Host
Malware Scan Port
Malware Scan Timeout (Seconds)
Menu Block 51 - WebLogic Advanced Environment Memory Configuration
WebLogic advanced environment memory configurations include:
Menu Option
Global JVM Arguments
GLOBAL_JVMARGS
Ant Min Heap Size
ANT_OPT_MIN
Ant Max Heap Size
ANT_OPT_MAX
Ant Additional Options
ANT_ADDITIONAL_OPT
Thread Pool Worker Java Min Heap Size
BATCH_MEMORY_OPT_MIN
Thread Pool Worker Java Max Heap Size
BATCH_MEMORY_OPT_MAX
Thread Pool Worker Additional Options
BATCH_MEMORY_
ADDITIONAL_OPT
Menu Block 52 - Advanced Web Application Configuration
Advanced web application configurations include:
Menu Option
HTTP Allowed Methods
HTTP_ALLOWED_METHODS
Web Application Cache Settings
WEB_L2_CACHE_MODE
Web Server Port Number
WEB_WLPORT
CSRF Protection For REST Services
CSRF_PROTECTION
OWSM Protection For REST Services
OWSM_PROTECTION_FOR_REST_SERVICES
Domain Home Location
WLS_DOMAIN_HOME
Batch Cluster URL
WEB_BATCH_CLUSTER_URL
Strip HTML Comments
STRIP_HTML_COMMENTS
Authentication Login Page Type
WEB_WLAUTHMETHOD
Web Form Login Page
WEB_FORM_LOGIN_PAGE
Web Form Login Error Page
WEB_FORM_LOGIN_ERROR_
PAGE
Javadocs Login Page
WEB_JAVADOCS_FORM_LOGIN_PAGE
Javadocs Form Login Error Page
WEB_JAVADOCS_FORM_LOGIN_ERROR_PAGE
Help Form Login Page
WEB_HELP_FORM_LOGIN_
PAGE
Help Form Login Error Page
ERROR_PAGE
Web Security Role
WEB_SECURITY_NAME
Web Principal Name
WEB_PRINCIPAL_NAME
Javadocs Security Role
WEB_JAVADOCS_ROLE_NAME
Javadocs Principal Name
WEB_JAVADOCS_PRINCIPAL_NAME
This is a development environment
WEB_ISDEVELOPMENT
Preload All Pages on Startup
WEB_PRELOADALL
Maximum Age of a Cache Entry for Text
WEB_MAXAGE
Maximum Age of a Cache Entry for Images
WEB_MAXAGEI
JSP Recompile Interval (s)
WEB_
WLPAGECHECKSECONDS
Enable Strict Transport Security
Strict Transport Security Max Age
HSTS_MAX_AGE
Strict Transport Security Include Subdomains
HSTS_SUBDOMAINS
Strict Transport Security Preload
HSTS_PRELOAD
User Interface Style
USER_INTERFACE_STYLE
Oracle Guided Learning Id
ORACLE_GUIDED_LEARNING_ID
Menu Block 54 - WebLogic Diagnostics
WebLogic diagnostic options include:
Menu Option
Diagnostic Context Enabled
WLS_DIAGNOSTIC_CONTEXT_ENABLED
Menu Block 55 - URI, File and URL Related Options
URI, File and URL Related Options include:
Menu Option
Customer
Install
Value
Enable CORS For Embedded UI
ENABLE_CORS
Allowed Frame Ancestors Max Number
CORS_ALLOWED_FRAME_ANCESTORS_MAX_NUMBER
URI For Variable CSP_FRAME_ANS_HOST1
CORS_CSP_FRAME_ANS_
HOST1
URI For Variable CSP_FRAME_ANS_HOST2
CORS_CSP_FRAME_ANS_
HOST2
Custom URL For CSP img-src
CSP_URL_IMG_SRC
Custom URL For CSP script-src
CSP_URL_SCRIPT_SRC
Custom URL For CSP style-src
CSP_STYLE_SRC
Custom URL For CSP font-src
CSP_FONT_SRC
Custom URL For CSP connect-src
CSP_CONNECT_SRC
Custom URL For CSP frame-src
CSP_URL_FRAME_SRC
URI For Variable FA_DOMAIN
CORS_FA_DOMAIN
URI For Variable ALM_DOMAIN
CORS_ALM_DOMAIN
Restriction URLs Enable
CLOUD_RESTRICTION_URLS_ENABLE
Custom SQL Security
CUSTOM_SQL_SECURITY
White List Full Path
CLOUD_WHITE_LIST_PATH
Custom White List Full Path
CLOUD_CUSTOM_WHITE_LIST_PATH
Substitution Variable List File Location
CLOUD_SUBSTITUTION_VARIABLE_LIST_FILE_LOCATION
Directory For Variable F1_CMA_FILES
CLOUD_LOCATION_F1_MIGR_ASSISTANT_FILES
URI For Variable F1_OAUTH2_URI
CLOUD_LOCATION_F1_OAUTH2_URI
URI for Variable F1_BASE_REST_URL
CLOUD_LOCATION_F1_BASE_REST_URL
URI for Variable F1_OPEN_API_BASE_URL
CLOUD_LOCATION_F1_OPEN_API_BASE_URL
URI For Variable F1_BASE_WEB_URI
CLOUD_LOCATION_F1_BASE_WEB_URI
URI For Variable F1_BASE_IWS_URI
CLOUD_LOCATION_F1_BASE_IWS_URI
Consolidated Logfile Full Path
CONSOLIDATED_LOG_FILE_
PATH
Temporary File Location
TMP_FILE_LOCATION
Menu Block 56 - Mobile Security Configuration
Note: The OUAF Mobile is not supported anymore, but the menu options still exist. They will be removed from the menu as well.
The Mobile Security configurations include:
Menu Option
Customer
Install
Value
Enable Mobile Application
MOBILE_ENABLED
Deploy Only Mobile Web Application
MOBILE_APP_ONLY
Mobile Application Directory
MOBILE_APPDIR
Allow Self Signed SSL Certificates
ALLOW_SELFSIGNED_SSL
Force Http Connection
FORCE_HTTP
Web Mobile Form Login Page
WEB_MOBILE_FORM_LOGIN_PAGE
Web Mobile Form Login Error Page
WEB_MOBILE_FORM_LOGIN_ERROR_PAGE
Menu Block 57 - REST Settings for JMX
REST settings for JMX configurations include:
Menu Option
Customer
Install
Value
Enable/Disable REST Service For The JMX
JMX_REST_SERVICE_FLAG
Hostname To Run The REST Server
JMX_REST_SERVICE_HOST
Batch Port For REST Server
JMX_REST_PORT_BATCH
Web Port For REST Server
JMX_REST_PORT_WEB
Business Server Port For REST Server
JMX_REST_PORT_SERVICE
Server Context
JMX_REST_CONTEXT
SSL Flag
JMX_HTTPSSL_FLAG
Keystore File Path
JMX_HTTPSSL_KEYSTORE_
FILE
Keystore Type
TYPE
Keystore Passphrase
PASSPHRASE
Keypair Passphrase
JMX_HTTPSSL_KEYPAIR_
PASSPHRASE
Trust Store File Path
JMX_HTTPSSL_TRUSTSTORE_
FILE
Truststore Type
TYPE
Truststore Passphrase
PASSPHRASE
Menu Block 60 - Advanced Configurations for OSB
The advanced configurations for OSB include:
Menu Option
Customer
Install
Value
Enable OSB SSL Port
false
OSB Trust Keystore Type
Demo
OSB Trust Keystore File Type
JKS
Menu Block 61 - Advanced Memory Configurations for SOA
The advanced memory configurations for SOA include:
Menu Option
Customer
Install
Value
SOA Initial Heap Size
1024
SOA Maximum Heap Size
2048
SOA Minimum Perm Size
512
SOA Maximum Perm Size
1024
SOA Application Additional Options
The name of the OWSM policy to use when SOA calls another SOA service
policy
The name of the OWSM policy to use when SOA is called by another SOA service
policy
The name of the OWSM policy to use when SOA calls an OUAF service
oracle/wss_http_token_over_ssl_client_
policy
Menu Block 62 - Advanced Memory Configurations for OSB
The advanced memory configurations for OSB include:
Menu Option
Customer
Install
Value
OSB Initial Heap Size
512
OSB Maximum Heap Size
1024
OSB Minimum Perm Size
512
OSB Maximum Perm Size
1024
OSB Application Additional Options
Menu Block 63 - Data Migration
The data migration configurations include:
Menu Option
Customer
Install
Value
Enable Data Migration
FALSE
Data Migration Database User
Data Migration Database Password
Menu Block 64 - Advanced Configurations for SOA
The advanced configurations for SOA include:
Menu Option
Customer
Install
Value
Enable SOA SSL Port
false
SOA Trust Keystore Type
Demo
SOA Trust Keystore File Type
JKS
Menu Block 70 - SSN SOA TestHarness Configurations
The SSN SOA TestHarness configurations include:
Menu Option
Customer
Install
Value
SSN TestHarness SOA Host Server
slc11cds.us.oracle.com
SSN TestHarness SOA Port Number
8920
SSN SOA TestHarness Partition Name
SSN_Test
SSN SOA TestHarness Queue JNDI Name
