Supported Platforms
The installation has been tested to operate on many operating system, application server, and database server combinations. For the software requirements for each of these combinations, refer to Installing Application Server Prerequisite Software.
Operating Systems and Application Servers
This section details the operating system and application server combinations on which this version of Oracle Utilities Digital Asset Management is supported.
Application Server Operating Systems
• Oracle Linux 8.x for x86_64
• Oracle Solaris 11.4+ for SPARC (64-bit)
• IBM AIX 7.2 TL5+ for POWER (64-bit)
Prerequisite Application Server Software
• Oracle Database Client 19c
• Oracle Java SE Development Kit 1.8.0_x (Solaris and Linux platforms)
• IBM 64-bit SDK for AIX 8.0.0.x (IBM platforms only)
• Oracle WebLogic Server 12c (Release 12.2.1.4) 64-bit
Notes:
Oracle Linux is 100% user space-compatible with Red Hat Enterprise Linux, therefore, Oracle Utilities Application Framework is also supported on Red Hat Enterprise Linux.
Refer to the Oracle Utilities Application Framework Database Administrator’s Guide for the Oracle database server requirements.
Refer to the Certification Matrix for Oracle Utilities Products (Document ID 1454143.1) document on My Oracle Support to determine if support for newer versions of the listed products have been added.
Please note the following:
• Version numbers marked with a “+” are the MINIMUM version supported. That version and all future 4th digit updates will be supported.
Example: Oracle 12.1.0.2+ means that 12.1.0.2 and any higher 12.1.0.x versions of Oracle are supported.
• An “x” indicates that any version of the digit designed by the “x” is supported.
Example: Linux 8.x indicates that any version of Linux 8 (8.0, 8.1, 8.2 etc) will be supported.
Windows Server
• Windows Server is not supported for Production environments. Wherever Windows Server is referenced within this guide, it is supported for Test or Development environments only.
WebLogic Server
• Oracle WebLogic Server (Fusion Middleware Infrastructure) and any higher versions of Oracle are supported.
• Customers must download Oracle WebLogic Server from the Oracle Software Delivery Cloud.
Oracle Database Server
Prerequisite database server software (on any vendor supported platform where x is vendor supported version):
• Oracle 19c (64-bit) On-Premises and Cloud (ADB)
Oracle VM Support
This version of Oracle Utilities Digital Asset Management is supported on Oracle VM Server for x86 for supported releases of Oracle Linux and Microsoft Windows operating systems.
Refer to My Oracle Support knowledge base article 249212.1 for Oracle’s support policy on VMWare.
Application Server Memory Requirements
For each application server environment a minimum of 4 GB of real memory is required, plus 6 GB of swap space. The approximate disk space requirements in a standard installation are as follows (the size represents the MINIMUM required):
Location
Size
Usage
Install Dir ("$SPLEBASE") Location
10 GB recommended
5 GB minimum
Location where the application and Framework get installed. Startup, shutdown and other online log files are stored here. The size and space that is used should be monitored because various debugging options can significantly affect the size of log files.
Note: This does not include the size of the edge product.
Log Dir ("$SPLOUTPUT") Location
10 GB recommended
2 GB minimum
Used for storing batch log files and output from batch jobs. The size of this space should be influenced by which batches are run and how often, and the amount of debugging information that is collected.
Location of the application web work files on the web servers
5 GB recommended
2 GB minimum
Used by various web server vendors to expand the application. It should be considered when installing these products.
Refer to the individual web server documentation to determine the location of the temporary files.
Installation Temporary Area
10 GB minimum
The application gets installed from this location. You need enough space to un-compress the files and install the application.
Oracle Data Area
10 GB minimum
Location is where the Oracle database data files are stored. The size of this space should be based on the requirements of the production environment. For an initial or demo database install 4 GB should be sufficient.
