Defining Time of Use Periods
You use the Time of Use portal is used to display and maintain time of Use periods.
Refer to Understanding Time of Use Periods for more information.
You can access the portal by selecting Admin, select Digital Asset Management, then select Time Of Use.
Time Of Use List: This zone lists all time of use periods records. Broadcast a record to display the details of the selected record.
Time Of Use: This zone provides information about the selected time of use period.
