Sample WebLogic Configuration Script
The following sample WebLogic configuration script is provided as part of the Oracle Utilities Application Framework application:
Unix
$SPLEBASE/tools/examples/bin/setUserOverrides.sh
Windows
%SPLEBASE%\tools\examples\bin\setUserOverrides.cmd
These scripts are intended as examples. The parameters shown here serve as a starting point for your configuration. Before deploying in your environment, you must review and redefine these values to suit your implementation. Do not use the provided sample values in production environments.
Prerequisites
Before running these scripts, make sure that the environment has been initialized:
Unix
splenviron.sh -e <ENV_NAME>
Windows
splenviron.cmd -e <ENV_NAME>
This step is required because the scripts retrieve option values from $SPLEBASE/etc/ENVITON.INI via getconfvalue.plx, and set java.login.config within the Java options.
If the environment is not installed locally, you need to modify these scripts to reflect your specific setup.
