Name | Reference Number | Description | Workaround (if applicable) |
Drop ILM Partition functionality doesn't drop the D1_MSRMT_CHAR table partitions. | Due to internal validations and special partitioning logic used for measurement tables, the drop ILM partition functionality can't drop the D1_MSRMT_CHAR table partitions. | ||
Drop ILM Partition functionality doesn't check the ILM_ARCH_SW as Yes. | The ILM_ARCH_SW field that determines the eligibility of the record to be archived is not being checked as part of dropping the partition using the Drop ILM Partition functionality. This is a critical issue and customers are advised to take the fix as soon as it get released. | Don't run the Drop ILM Partition for any table until the fix is released and your environment is upgraded to the latest version that includes the fix. | |
Oldest table partitions not shown on ILM Dashboard | The oldest partition of a table that has more than four (4) years of partitions is not shown on the ILM Dashboard. As a result, users cannot currently drop the oldest partition for tables that have more than four (4) years of partitions. |
