Highest Energy Use Days
The Highest Energy Use Days calendar highlights the top five days of the month in which a customer used the most energy, helping them identify patterns in their energy use.
Highest Energy Use Days Example
The following image shows a standard example of the Highest Energy Use Days, and indicates the primary configuration options.
Example screenshot showing a May calendar highlighting the top five days of highest energy use, with a note that energy use was highest on Tuesdays. A button labeled "See energy details" is also visible.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Configuration Option Input Value
1. Number of Top Energy Use Days to Highlight
A calendar and legend highlight the days of the month with the highest energy use. The number of days highlighted can be configured.
Default: Five days.
Optional
Choose one of the following:
  • Use the default option.
  • Provide the number of days to highlight.
User Experience Variations
The user experience of the feature may vary for customers and utilities depending upon their service types (gas, electricity, dual fuel, and so on), available data, locale, and other factors. For more information, see Highest Energy Use Days in the Digital Self Service Energy Management Cloud Services Overview Guide and go to the User Experience Variations section.
