Tips List
The Tips List widget displays the top five energy efficiency tips for a customer's household. The priority and order of the tips is determined based on data that is available for the customer. The widget can be coupled with the Home Energy Analysis or it can be standalone. The purpose is to promote customer interest in tips and guide them to more energy efficient behavior.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
| Configuration Option | Input Value |
Maximum Tip Guides to Display Change the maximum number of tip guides that can be displayed for a customer. Default: The maximum number of tip guides displayed is three. |
Optional Choose one of the following:
