Single Logout (SLO)
Single Logout (SLO) is not a supported feature of Solution Extension partner SSO. The SLO profile of the SAML 2.0 specification provides for coordinated and near-simultaneous logout across applications with a federated authentication context. However, because the integrations between the utility, Oracle Utilities, and Solution Extension partner requires an identity bridge, full end-to-end SLO is not possible.
By default, the Energy Efficiency Web Portal has a user session inactivity timeout of 30 minutes, which is configurable on a per-client basis. The Solution Extension portal must be able to configure user session inactivity timeout to meet utility requirements and offer a consistent experience for the user across all service providers.
