Customize Branding
Oracle Cloud Infrastructure Identity and Access Management branding customizations include the application logo, company name, contact email addresses, and notification email address.
To update Oracle Cloud Infrastructure Identity and Access Management branding:
  1. Log in to the Oracle Cloud Infrastructure Identity and Access Management Admin console. Navigate to your domain and select Settings, and then select Domain Settings.
  2. Update the Contact area with applicable email addresses. For example, enter: customerservice@UtilityCo.com. Select Save changes as required.
  3. From the same Settings, select Notifications, and then update the Sender's Email Address. For example, enter no-reply@UtilCo.com. Select Save changes as required.
  4. From the same Settings, select Branding and then choose custom branding.
  5. Update the Company name. For example, enter: UtilityCo.
  6. Upload the Company logo, which is used in the console and email templates header and footer. Select Save changes as required.
