HVAC Adjustment
The HVAC Adjustment module provides customers with a recommended thermostat adjustment for the season. It also includes an additional recommendation to purchase a smart thermostat in order to automate seasonally appropriate savings on heating or cooling.
Appears in: Seasonal Report
HVAC Adjustment Example
This image shows an example of the HVAC Adjustment experience for a customer who receives the summer Seasonal Report.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
| Configuration Option | Input Value |
Source The recommended adjustment tells the customer how they should modify their thermostat as recommended by an official source. Default: Department of Energy |
Optional Select one of the following:
Details The details encourage the customer to make saving energy easier by purchasing a smart thermostat so that they can automate their thermostat adjustment. Default: See example image above. |
User Experience Variations
The user experience varies for customers depending upon their service types, available data, costs, and locale. For more information, see the HVAC Adjustment topic in the Oracle Utilities Opower Energy Efficiency Cloud Service Overview.
