Configuration Options
Configuration Option Input Value
Prompt
Utilities may configure the prompt to reinforce the report promotion. For example, "Is this heat pump water promotion relevant to you?"
Default:
  • Progress Report Module: "How useful was this email?"
  • Promotion Report Module: "Is this promotion relevant to you?"
Optional
  • Use the default header.
  • Provide alternate configuration.
