Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Configuration Option Input Value
Disclaimer
The disclaimer explains to the customer why the customer is receiving the report.
Default:
"You were selected to receive this report because you may be using more than the regional average for this energy use category. Numbers are approximate."
Optional
Choose one of the following:
