Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Configuration Option Input Value
Benchmark Header
The heading notifies the customer that the benchmark gives them an at-a-glance view of their energy use. It also includes the customer's fuel type.
Default: "Your <fuel type variation> use at a glance."
Optional
Contact Your Delivery Team about configuring the benchmark header.
Color Labels
The benchmark has three potential states, and each corresponds to a color. The labels (Fair, Good, and Great) are configurable. However, the default labels and colors are strongly recommended.
Default:
  • Orange: Fair. Customer is using more than Similar Homes.
  • Yellow: Good. Customer is using more than Efficiency Zone /Efficient Neighbors threshold, but less than Similar Homes.
  • Green: Great. Customer is using less than the Efficiency Zone/Efficient Neighbors threshold.
Optional
Choose one of the following:
Benchmark Copy
The copy below the gauge tells the customer how they can leverage the report or recognizes a change in state.
Default:
The copy defaults vary by fuel type and the customer’s energy use. Discuss the default language with your Service Delivery Manager.
Optional
