HVAC Adjustment
The HVAC Adjustment module provides customers with a recommended thermostat adjustment for the season. It also includes an additional recommendation to purchase a smart thermostat in order to automate seasonally appropriate savings on heating or cooling.
Appears in: Seasonal Report
Requirements
No utility or customer data is required to generate this module.
User Experience
The image below shows an example of the HVAC Adjustment experience for a customer who receives the summer Seasonal Report.
Image of a Thermostat Adjustment experience for a customer that receives the summer Seasonal Report
Module Label: The label identifies the season applicable to the thermostat adjustment.
Header: The header encourages customers to adjust their thermostat setting while away from the home to save energy.
Image: An illustration is paired with large number call out of degrees to raise the thermostat.
Recommended Adjustment: The recommended adjustment tells the customer how they should modify their thermostat as told by an official source, such as the Department of Energy.
Details: The details encourage the customer to make saving energy easier by purchasing a smart thermostat so that they can automate their thermostat adjustment.
User Experience Variations
Winter Seasonal Report HVAC Adjustment
The winter version of the HVAC Adjustment module varies from the summer version in several ways. The label identifies the winter season for the thermostat adjustment, and the header encourages customers to adjust their thermostat to save energy when they go to bed. An illustration is paired with the temperature callout advising customers to lower their thermostat.
