Thermostat Adjustment
The Thermostat Adjustment module provides customers with a recommended thermostat adjustment for the season. It also includes an additional recommendation to purchase a smart thermostat in order to automate seasonally appropriate savings on heating or cooling.
Appears in: Seasonal Report
This image shows an example of the Thermostat Adjustment experience for a customer that receives the summer Seasonal Report.
Module label: The label identifies the season applicable to the thermostat adjustment.
Header: The header encourages customers to adjust their thermostat setting while away from the home to save energy.
Image: An Illustration is paired with large number call out of degrees to raise the thermostat.
Recommended Adjustment: The recommended adjustment tells the customer how they should modify their thermostat as recommended by a source. For example, the Department of Energy.
Details: The details encourage the customer to make saving energy easier by purchasing a smart thermostat so that they can automate their thermostat adjustment.
Requirements and Limitations
Fuel: Electric-only, gas-only, dual fuel
Data Required: Appliance detection and disaggregation, heating and cooling disaggregation and/or simple disaggregation with Home Energy Analysis completion
Data History: A minimum of one historical bill
Billing Frequency: Monthly, bi-monthly, or quarterly
