Batch Details
This section displays all details about the batch job selected in the Active Batch Job section. The following table describes the displayed fields:
Table 4-4 Batch Detail
Field Comment Source
Summary
Batch Code Batch Control Id BatchCd
Thread Thread Number ThreadNumber
Thread Limit Max number of threads ThreadCount
Batch Number Batch Run Number BatchNumber
Program Name Program running ProgramName
Run Type Type of Run RunType
Execution Strategy Execution Commit Strategy ExecutionStrategyClass
Common Parameters
Language Language Code used LanguageCd
Maximum Commit Records Commit Frueqency MaximumCommitRecords
Maximum Timeout (min) Commit Timeout MaximumTimeoutMinutes
Business Date Business Date used for job ProcessDate
ReRun Number Rerun Number for reruns RerunNumber
Thread Pool Thread Pool allocated to DistThreadPool
Name JVM Name
UserId User Running Job UserId
Trace Program Start Is Tracing on for Start of job? TraceProgramStart
Trace Program End Is Tracing on for End of job? TraceProgramEnd
Trace SQL Is Tracing on for all SQL in job? TraceSQL
Trace Standard Out Is Tracing on for debug messages for job? TraceStandardOut
Performance Summary
Elapsed Time Elapsed Time since start ElapsedTime
Date Time Started Date Time Job started DateTimeStarted
Max Execution Attempts Number of executions MaxExecutionAttempts
Cancel Requested If job has been cancelled recently CancelRequested
Requested By If CancelRequested = true then OS userid of person who requested the cancel CancelRequestedBy
Records Committed Number of records processed so far RecordsCommitted
Records in Error Number of records in Error so far RecordsInError
Work Unit Size Size of Work unit within Execution Strategy WorkUnitSize
Work Unit Size This Run Work Unit used for this run WorkUnitSizeThisRun
Work Units Committed Work Units Committed so far WorkUnitsCommitted
Work Units In Error Work Units errored so far WorkUnitsInError
Work Units Processed Work Units processes so far WorkUnitsProcessed
Additional Parameters (List of parameters from SoftParameters)
Parameter Parameter Name Element before = in array
Value Parameter Value Element after = in array
The thread details are part of default collections, and only when a Refresh button is clicked will the details be refreshed by calling a job or by getting the latest information from the default collections.
