Known Issues: Enterprise Manager for Oracle Utilities
The following are known issues in this release of Enterprise Manager for Oracle Utilities.
| Module | Bug/Issue | Description |
Batch Home Page |
23146097 - COLUMN "MAX EXECUTION ERROR" IN BATCH HOMEPAGE IS OUT OF PLACE WHEN VIEWED IN IE |
The Column mentioned is out of alignment when the accessibility tool is turned on. |
Target availability |
Bug 22918639 - NATIVE ENV TARGETS UNAVAILABLE AFTER TARGET REMOVAL THEN DISCOVERY/PROMOTION |
A native or clustered OUAF environment’s web and service target availability cannot be determined by the plug-in. |
Target promotion |
Bug 22611107 - UNABLE TO START/STOP IN DISTRIBUTE INSTALL TARGET ENVIRONMENT |
When distributed targets are promoted from a specified agent (e.g., Agent A), OEM does not honor the association with any other agent/host other than that agent. Bug 22741274 - target with remote agent using setAgent api. |
Environment Home Page |
IE :SYSTEM PROPERTIES TEXT IN THE ORACLE UTILITIES ENV TARGET ARE CUT OFF ACC |
System properties in the home page is not visible when viewed in IE with accessibility mode turned on. |
Target Home Page for native install |
Monitoring issues exist in environments using localhost as the hostname. |
If an environment is configured with localhost as the hostname, the following issues can occur:
Cloning |
Unable to Clone |
Due to ADF user interface bug, we face a null pointer issue on the screen. As a workaround, you could navigate forward and backward, after which - this screen/functionality works. |
Upgrade |
Target Availability issues after migration to latest version |
Due to OEM upgrade issue, we run into this issue. As a workaround, check the installation documentation |
