2 Comparing Typical and OEM-Compliant Packaging
OUAF-based service packs available on Oracle Support are typically packaged in the format pBUG_NUMBER_VERSION.zip. The package includes the Framework installer and application installer. A Framework rollup installer may also be packaged with it.
Each installation has two parts: the database installation and the application installation. Separate installers are therefore available for each type of installation.
The following image illustrates the structure of a typical OUAF service pack:
Typical OUAF service pack structure
Filename Contents Description
*Oracle-Database-MultiplatForm.zip *Oracle-Database-MultiplatForm Contains framework and application installer for database
*FW-PREREQ- MultiplatForm.zip *FW-PREREQ- MultiplatForm.jar Contains the Framework application rollup installer
<application>-<version>- MultiplatForm.zip <application>-<version>- MultiplatForm.jar Contains application installer
FW-<version>- MultiplatForm.zip FW-<version>- MultiplatForm.jar Contains the Framework application installer
OEM-Compliant Packaging Structure
A service pack must be packaged in a different way to enable installation by the Enterprise Manager for Oracle Utilities plugin.
Structurally, it must include the following three top-level items:
  • App folder. This folder contains application installers, e.g., the edge product installer, the Framework installer, and the Framework rollup installer (if any).
  • DB folder. This folder contains database installers for OUAF and the edge product.
  • Metadata.xml. This file contains the sequence of execution of the installers. This needs to be created separately and then included in the final Service Pack zip file.
The following image illustrates a compliant service pack structure:
OEM-compliant service pack structure
The next topic describes the steps involved in repackaging an existing Service Pack to make it OEM compliant.
