OUAF Release 4.3.0.0.0
Bug: This change was made to pass down the action details to BusinessObjectEnterStatusAlgorithmSpot and BusinessObjectExitStatusAlgorithmSpot.
17230588 - EXPOSE ACTION IN BO STATUS PLUG-IN SPOTS
com.splwg.base.domain.common.businessObject. BusinessObjectEnterStatusAlgorithmSpot
New Method:
* Set the Action of Business Object
void setAction(BusinessObjectActionLookup boAction);
Change Description: The method is added to the plugin spot to pass down the action information to all implementation classes.
Note: As the spot is changed, all implementation classes should implement the method. Implementation can be left blank if the algorithm does not need the action information.
Code Example 1 (preferred):
//Before Code:
There was no setAction() method.
//After code:
public void setAction(BusinessObjectActionLookup boAction) {
// null
com.splwg.base.domain.common.businessObject. BusinessObjectExitStatusAlgorithmSpot
New Method:
Note: As the spot is changed, all implementation classes should implement the method. The implementation can be left blank if the algorithm does not need the action information.
//Before Code:
//After code:
// null
Bug Fix: JS API - handleExpand/handleCollapse Methods in xslInclude.js
Bug: handleExpand() and handleCollapse() functions in xslInclude.js used to expand/collapse a zone. Prior to Framework 4.3, these functions expected one or two arguments to expand/collapse a zone. However, since the release of Framework 4.3, these functions do not work as expected with a single argument. They now accept only two arguments, e.g., sequence id of the zone, and user event object, to work as expected. The API change was a part of overall standardization and adoption of best practices for the JS layer to enable cross-browser support. Refer to patch 23745289 for details.
