What are Not APIs?
Avoid calling other packages not mentioned above. The code is not designed to be called outside of OUAF code. For example, avoid the following packages:
•	com.splwg.base.support.*
•	com.splwg.base.web.*
•	com.splwg.base.xai.*
These are often specialized calls intended to be used within the Application Framework. Calling specialized methods may, for example, change processing behavior by introducing unexpected events or skipping optimizations.
